The difference between a 351M & a 400
Old Apr 7, 2003 | 02:51 PM
130loadmaster's Avatar
130loadmaster
I have a 1978 Ford F250 and a cant tell if it has a 351M or a 400. How can I tell the difference..........
Old Apr 7, 2003 | 05:07 PM
78bigbronco's Avatar
78bigbronco
The only way I know to tell the difference is probably to get the motor tested for cylinder displacement. Not exactly sure how they do that but I have seen it done in racing were motors have to meet certain guidlines for class restrictions.
Old Apr 7, 2003 | 06:36 PM
Bill_Beyer's Avatar
Bill_Beyer
You can try to measure the stroke through the spark plug hole but the best way to tell is to drop the oil pan and look at the casting numbers on the crank. 5M, 5MA or 5MAB is a 400 crank. 1K is a 351M crank. The casting code should be on the first crank throw.
