GOOD DEAL
Old Sep 29, 2011 | 06:40 AM
HILLBILLY BOB's Avatar
HILLBILLY BOB
GOOD DEAL
A friend of mine is cleaning out a bunch of stuff from his garage & he said that he is going to sell his 351W & C6 & if i wanted it he would give it to me for $300,it is a good running engine.what is the difference berween
the 351c & 351w?
Old Sep 29, 2011 | 07:08 AM
heavyhitter 460's Avatar
heavyhitter 460
351w is a small block and 351c is a big block.
Old Sep 29, 2011 | 07:09 AM
heavyhitter 460
if you don't want them i'd like to talk to him.
Old Sep 29, 2011 | 09:53 AM
52 Merc's Avatar
52 Merc
Actually, that is incorrect. Both engines are small blocks, but from different engine families. Both use the same bore, stroke and bore spacing. But they are two, distinctly different engines where the only interchangable part is the flywheel.
They're easily identified by the valve covers, water neck and fuel pump. Windsor valve covers look just like a 302 with 6 bolts. Cleveland valve covers are much larger and have 8 bolts. Windsor water necks come out of the front of the intake, where the Cleveland has theirs coming straight up out of the timing chain extension cast into the front of the block. Fuel pump bolts are unusually vertical on the Cleveland, where on the Windsor they are the conventional, horizontal style found about everywhere else.
Old Sep 29, 2011 | 09:55 AM
52 Merc's Avatar
52 Merc
the 351c & 351w?
Find out what it's out of. It would be unusual to find a 351W with a C6. More commonly they came with FMX transmissions.
Old Sep 29, 2011 | 10:10 AM
heavyhitter 460
i think the old cougars and possibly mustangs sometimes came with that combination. if they came out of one of those I am definitely interested. i'm pulling a 289 out of a cougar now.
Old Sep 29, 2011 | 10:24 AM
Grubbworm's Avatar
Grubbworm
I had a friend in high school with a Cougar (I think it was a '70), 351c and fmx.
Old Sep 29, 2011 | 10:57 AM
old_dan's Avatar
old_dan
A 351w and a C6 would be common in an 80's F150 and some vans....they called it the 5.8l version at that point.
Dan
Old Sep 29, 2011 | 11:07 AM
heavyhitter 460
Dan
i'd still be interested. where is the oil sump? toward the front or back?
Old Sep 29, 2011 | 11:25 AM
old_dan's Avatar
old_dan
The trucks and vans have a rear sump pan....well....it has a hump in the middle and a front section that generally hangs over the front crossmember, but the deepest part is in the back. Here's a pic of the F150 version:
Old Sep 29, 2011 | 12:26 PM
Stephen67's Avatar
Stephen67
Thats a good deal. The 351w is a great engine. W= windsor, C= Cleveland, M=Modified, all named after where they where built. The Cleveland for a long time was thought to be better but over the years the windsor started to have a lot more parts be made for it and suddenly you could have a rather big engine that weighed a lot less making more power. In Mustangs they are used often because a lot of 302 parts work, especially the transmissions, so you could do the swap easy enough, verse needing more room, putting more weight and needing a different transmission of a 351c.
Old Sep 29, 2011 | 10:37 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
the 351 cleveland, 351 modified, and 400 are all the same engine family.
I have had 1 of each motor in the same vehicle. '78 Ford Bronco...I still miss her...
I have heard people complain about the 351M and 400, and nothing but praise on the 351 Cleveland. the only thing I ever heard about the 400 was cooling issues. But who knows what that was based on. opinions are like A-holes, everyones got one and they all stink!
Ok so the 351 Windsor, as far as the block, is alone correct?
It is different from the 289/302 because it's deck ht is taller and it's wider? right?
Old Sep 29, 2011 | 11:09 PM
Mervy49's Avatar
Mervy49
The 351w and mating c-6 also came in a 1977 E 150, that's what I got in my 49.
Last edited by Mervy49; Sep 29, 2011 at 11:10 PM. Reason: wrong pic got in the way
Old Sep 29, 2011 | 11:10 PM
Stephen67's Avatar
Stephen67
I thought it was in the same family as the 302. Least I know a lot of parts are interchangeable and its sometimes hard to tell the difference between the two.
Old Sep 29, 2011 | 11:12 PM
Mervy49's Avatar
Mervy49
the 351c & 351w?
That's a really good price for the two
