my progress thread/build
Old Oct 11, 2011 | 08:27 AM
  #31
tmcalavy's Avatar
tmcalavy
wow! I gotta quit readin this thread...all the eye candy is making me slobber and my wallet is pretty slim these days.
Old Oct 11, 2011 | 11:01 AM
  #32
elgemcdlf's Avatar
elgemcdlf
You ain't kiddin. I would love to say I had 815 CID!
Old Oct 11, 2011 | 11:20 AM
  #33
MIKES 68 F100's Avatar
MIKES 68 F100
that is a sweeett motor !
Old Oct 11, 2011 | 11:21 AM
  #34
MIKES 68 F100
any sound/video of that beast ?
Old Oct 11, 2011 | 01:09 PM
  #35
elgemcdlf's Avatar
elgemcdlf
All I have is that pic as is and in the car. Came from Big Block Fords a site that caters to the 385 Ford
Old Oct 12, 2011 | 04:20 AM
  #36
94z28's Avatar
94z28
sc FE
Old Oct 12, 2011 | 04:28 AM
  #37
94z28's Avatar
94z28
Old Oct 15, 2011 | 06:09 AM
  #38
94z28's Avatar
94z28
so whats the deal with power steering on a non power steering truck like mine? I have read alot of different stuff i want front discs as well
Old Oct 15, 2011 | 08:03 AM
  #39
tmcalavy's Avatar
tmcalavy
Well, you can install Arm-strong steering by working out more, to beef up your shoulders and arms, or you can pull the manual steering gear box and drop in a PS box...but you'll also have to add a PS pulley, pump, lines, and different steering column. But if you're gonna do the power disc brakes, it won't be that much more work to change to PS. Search the forum here and at fordification.com...there's lots of threads/posts on both swaps with pix that show&tell the whole process. If you're on a budget, Armstrong steering is way more economical.
Old Oct 15, 2011 | 08:10 AM
  #40
94z28's Avatar
94z28
I hear i can keep my column so thats why i ask.... I have read up and want to keep my flawless column. Actually i had no clue it wasnt power steering when I first drove it
Old Oct 15, 2011 | 02:11 PM
  #41
tmcalavy's Avatar
tmcalavy
Nothin' wrong with manual steering...only time it sux is at a dead standstill, when you need to move the wheels. As for the PS swap, there are two gearboxes...Bendix (junk) and Ford Saginaw (rebuildable, reliable). Bendix was used stock up to 70 or 71 I think, after that it was the Saginaw box. Bendix boxes leak and eventually crater out of the bottom seal, and run/operate hotter. If you do the conversion, go with a Saginaw gearbox and save yourself some future headache.
Old Oct 17, 2011 | 04:55 AM
  #42
94z28's Avatar
94z28
hmmm sounds good how do i make it work with my column? or what column would i need? and 73-? what for my disc brakes
Old Oct 17, 2011 | 07:12 AM
  #43
tmcalavy's Avatar
tmcalavy
okay, go here and start reading:
Technical Articles Index - FORDification.com
Old Oct 17, 2011 | 07:54 PM
  #44
19shorty68's Avatar
19shorty68
Originally Posted by MIKES 68 F100
well if you got the $ for aluminum intake , putting a cast iron on is a p.i.t.a.
360 is not a good motor to mod carb and intake won't make much difference .
find a donor 390 (same block as 360) build it then swap .
I got a 390 that im hauling to the dump. Putting in 302 ;-)
Old Oct 17, 2011 | 08:20 PM
  #45
MIKES 68 F100
shorty put it on craigslist , you'll get something for it .
or if you are in so cal i'll pick it up .
