Tire size/speedo reading
Old Sep 27, 2011 | 11:34 AM
jgoodman6891's Avatar
jgoodman6891
My '94 is running the stock size tires & says 13.1 or 13.2 miles from my house to work.
My '85 has 215/85r16 on the drive axle & 235/85r16 on the steer axle. The sticker on the door jamb does not list a tire size. The other night it showed 18.xx miles to work. A solid 5 mile difference.
I know going to a taller tire will slow down a speedo & smaller speed it up. I used the calculator here. According to it, the speedo reads ~2.5mph fast.
Ive had a brain fart for the last hour trying to figure up if swapping the 235s to the drive axle will correct it. Cant find a calculator online to figure it up or come up with something on paper.
3.54 is (should be) the axle ratio. It seems fairly tall geared & the cover hasnt been removed in years so Im pretty sure I have 3.54.
Any help figuring this out would be greatly appreciated.
Old Sep 27, 2011 | 11:57 AM
ctubutis's Avatar
ctubutis
Does anything here help?
Automotive Calculators offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com
Old Sep 27, 2011 | 12:17 PM
jgoodman6891
Not really... but thanks
Old Sep 27, 2011 | 12:50 PM
f100jim's Avatar
f100jim
Changing from 215's on the drive axle to 235's will lower your 18.x mile odometer reading to around 16.x. It won't get you down to 13.x
Old Sep 27, 2011 | 12:51 PM
Grubbworm's Avatar
Grubbworm
What about going from 215's to 31x10.50's?
Old Sep 27, 2011 | 02:46 PM
f100jim's Avatar
f100jim
A 215/85R16 is 30.4" in diameter.
A 235/85R16 is 31.7" in diameter.
Assuming a 31x10.50 is 31" in diameter (I assume that is what the "31" means) it would actually correct your spedo/odometer LESS than the 235/85R16.
To get your odometer reading from 18 miles (with the 215/85R16) down to 13 you would need a tire that is 42.1" in diameter! You are not going to get there with a tire change. You are going to have to change speedo gears to correct it.
Phx Raven
Nov 20, 2022 02:40 PM
gustrider4
Jan 27, 2016 08:52 PM
boulderbronco
6.4L Power Stroke Diesel
Jul 9, 2013 09:28 PM
Superduty.pride
32
Oct 14, 2011 07:11 PM
MR_F-350_4X4
Modular V10 (6.8l)
Mar 1, 2004 10:02 AM
