Modular V10 (6.8l)
Odometer/speedometer Calculation
Old Feb 28, 2004 | 01:37 PM
MR_F-350_4X4's Avatar
MR_F-350_4X4
Question Odometer/speedometer Calculation
I am ridding on 38's on a f-350 4x4 my speedometer is obviously off. cant afford a module to correct this yet but was wondering if anyone knew a calculation that would tell me a correct odometer reading. my speedometer is about 10 miles per hour off
Old Feb 28, 2004 | 01:53 PM
V10DoubleTow's Avatar
V10DoubleTow
To make a correction without a comp mod, you'll have to always calculate a percentage from original. I'll need to know your original tire size to give you that. Of course, that assumes your speedo was correct before the tire change. What was your original tire size? Check the door post. As your comp will always be off, your performance will suffer too. I don't think that you can ever get a full correction with 38's. I think that the comp can only be corrected to 35's max. Somebody will correct me if I'm wrong on this.
Old Feb 28, 2004 | 04:06 PM
73Fastbackv10's Avatar
73Fastbackv10
I posted this under "RPMs at 60", but here is a link for actual speed--it uses RPM, gear ratio, and transmission ratio to calculate actual speed.
http://www.csgnetwork.com/rearendgearcalc.html
Here is one for tire size changes, too.
http://www.csgnetwork.com/speedocalibcalc.html
I hope that you find these helpful.
Old Feb 28, 2004 | 11:10 PM
BigRedSuperduty's Avatar
BigRedSuperduty
I took mine to the dealer they got me within 1 to 2 mph of correct at 70. It seems to be right on at 55. Only charged me $20
Old Feb 29, 2004 | 01:45 PM
MR_F-350_4X4
thanks for the help my o.g. tire size was 265/75/r16
Old Mar 1, 2004 | 10:02 AM
99 sd v10's Avatar
99 sd v10
Do what Bigred did. You'll be pretty close. Go with the smallest 3 digit number in (###) next to the tire size choice. My dealer wasn't aware of this, but did it and was happy to know. It's been requested of him often. he just was picking one and seeing what happened.
