Any old-school tricks for "loosening" a tight V-8?
Old 09-25-2011, 10:09 PM
NightTrain55's Avatar
NightTrain55
NightTrain55 is offline
My rebuilt 428 is pretty tight. I can turn it from the front bolt on crank,but it takes a little bit of muscle. Therefore, seems like a lot of stress for the starter. We did do the initial 20 minute break-in run. Still tough on start-up! Any tricks other than just to keep on running it?
Old 09-25-2011, 10:12 PM
BlueOvalRage's Avatar
BlueOvalRage
BlueOvalRage is offline
Nope. It just needs to run in and it will loosen up. Just sitting and idling probably won't do much for it, either. It needs to see some loaded mileage. In the near term, as long as it starts, runs, and carries good oil pressure, you've got no worries.
Old 09-25-2011, 10:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Hastings (as in piston rings) has an excellent write-up on breaking in a fresh rebuilt engine:
Breakin Procedure
Old 09-26-2011, 10:43 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
Received 3,911 Likes on 1,865 Posts
A fancy dinner and a diamond encrusted bracelet maybe......
Old 09-26-2011, 11:41 PM
BACAGrizz's Avatar
BACAGrizz
BACAGrizz is offline
Don't forget champagne, candle light and Barry White!
Old 09-26-2011, 11:53 PM
lexcoe's Avatar
lexcoe
lexcoe is offline
Yeah, especially Barry White....LOL Geez you guys crack me up. John
Old 09-27-2011, 01:36 AM
iwanaflattie's Avatar
iwanaflattie
iwanaflattie is offline
roofies on the champange(gasoline)
Old 09-27-2011, 11:57 AM
old_dan's Avatar
old_dan
old_dan is offline
He said he want to loosen up the engine....he doesn't want it to forget that he broke it in!!!
Run it and make sure that your starter has good connections...especially the ground...sometimes paint on a fresh rebuild will insulate the starter a little & result in slow cranking. Also check the connection of the battery ground to the block.
Dan
soco
04-07-2014 03:40 PM
fixnair
21
11-28-2012 06:25 PM
rodeojunky
18
09-04-2010 08:36 PM
chromiumh1
09-13-2004 03:24 PM
1BADHD
Modular V8 (4.6L, 5.4L)
07-10-2003 02:01 PM
Quick Reply: Any old-school tricks for "loosening" a tight V-8?
