Sponsored by: Kumho
Do tires really make the difference?
Old Sep 27, 2011 | 05:45 AM
Titan12345's Avatar
Titan12345
I have a f250 with a 6 inch lift and 16" wheels and tires but 285-70. I was talking about a bit of excessive play in the steering compared to stock. Someone mentioned it might be the tires. He said that since the tires are larger than stock, the extra play in the larger sidewall on the 285 shows up as extra play in the steering wheel. He said I need to consider a tire with a more rigid sidewall. Does anybody have any experience with this?
J
Old Oct 3, 2011 | 09:02 AM
4x41977's Avatar
4x41977
I would doubt its the tires unless your running C rated tires and a lot of weight. Most likely somewhere in your steering linkages
Old Oct 3, 2011 | 10:31 AM
Titan12345's Avatar
Titan12345
I know the length of the pitman arm probably has somehting to do with it, I know it was changed, but not sure what I need to do clear up the play.
I know the stock pitman arm is too short.
john
Old Oct 3, 2011 | 11:18 AM
4x41977's Avatar
4x41977
Check ball joints, tie rod ends, bushing, etc I have a 6 in lift and 35 without a steering stabalizer and steers great
Old Oct 3, 2011 | 01:54 PM
Titan12345's Avatar
Titan12345
4x41977: You had to change your Pitman are, right?
I bought the truck already lifted and I had to change a tie rod. Nothing else on the front end was sloppy except it needed shock bushings. (odd) but that helped but I still have about 11:30 to 12:30 play in the wheel.
Old Oct 3, 2011 | 02:16 PM
4x41977's Avatar
4x41977
I have a drop pitman arm. Somewhere has slop in it. My suggestion have someone sit in truck and turn wheel and start from the begining
bpimm
15
Apr 5, 2018 09:20 AM
19tanker
Aug 17, 2015 04:21 PM
t_b0ne
18
Jun 1, 2015 10:15 PM
acw592
Mar 4, 2009 01:39 PM
zekeman
2004 - 2008 F150
27
Mar 22, 2007 03:47 PM
