Painting the Expy again!
Hood is bubbling, in a few spots the paint has flaked off. Again.
Service writer already took pictures and got the repairs authorized with Ford. Have to see what my work schedule is and then take it in for a 4th painting. Joy. Also need to pre-call Ford and make sure they give me a big enough rental this time.
read your warranty card. the hood and trunk are made of aluminum. known corrosion problems.
Ford has a pretty long warranty term for corrosion. i just can't remember what it is. If your mileage/age falls under it, just visit the Dealership and point that out. I've already had my rear hatch fixed once for this
Expy has been at Ford since Monday. Waiting to see if I'll have it back today or not.
The corrosion warranty is BS. It calls for complete rust through. That is very severe and even without paint or primer wouldn't happen within the time they list. The problem with the trunk and hood is Ford does not know how to properly prep the metal and that is why you get the bubbles and paint failure.
It came back worse than I dropped off. They didn't fix corrosion...just sanded and sprayed paint over top. Then they burned through paint BADLY in several places. It's noticeable from 5+ feet away
2nd Dealership, 3rd shop painting. Exact same problem as in 2009
Topper is they drove it ~16 miles, burned a 1/4 tank of gas, and for some reason rifled through entire vehicle. I've found stuff out of place and buttons, settings changed on everything
Pics to come shortly
Edit: oh yeah, and crackheads scratched hell out of Passenger quarterpanel
Started raising hell with Dealership. No Managers at work. Told nice lady they had 30 minutes to find one or they could explain to owner why I filed a BBB Complaint
Strangely enough, a Manager was found. Had no explanation for the problems. Wants me to bring it back in Tuesday.
5th time for paint upcoming. Anybody care to place bets on a 6th or 7th attempt? I can't file a complaint with Ford as it's past their working hours. I'm going to make a complaint Monday
