alignment question
Old Sep 26, 2011 | 07:04 PM
cbkalpine's Avatar
cbkalpine
alignment question
I have a '92 f250 4x4. The front springs have sagged to the point where they are about a half inch from hitting the bump stops. I have put new spring bushings in it. If i put a 1.5" add a leaf in the front springs, will the alignment still be doable or will i need to add drop brackets. Thanks for your help.
Old Sep 26, 2011 | 07:36 PM
DBGrif91's Avatar
DBGrif91
I guess I'm not sure what you mean by "will the alignment still be doable..."?
Do you mean will adding the leafs throw off the alignment, or you are planning to take it in for an alignment and you want to know if adding the leafs will affect that?
Old Sep 26, 2011 | 08:00 PM
cbkalpine's Avatar
cbkalpine
Sorry. I guess what i mean is how much lift can i do on the front without the drop brackets.
Old Sep 26, 2011 | 09:23 PM
Encho's Avatar
Encho
The Southernmost Mod
Very little, like 2 1/2 in.
HeavyE85
May 4, 2018 05:18 AM
rm.lydon08
May 15, 2012 09:53 AM
ItsAFord55
20
Aug 2, 2011 10:20 PM
xc4jokestomper
13
May 30, 2011 04:43 AM
wileec
1978 - 1996 Big Bronco
May 15, 2002 03:44 PM
