ride quality
Old Sep 26, 2011 | 08:12 AM
Joe28443's Avatar
Joe28443
Joe28443
ride quality
I know this has been discussed several times. If not driving on a smooth surface and I mean smooth, it rides like crap. You feel every tiny crack in road. My question is if you swap the springs for v/b codes. Will it not ride a little rougher with truck springs? I know I got to do body mounts. Will that cause it to feel every bump in road?
Old Sep 26, 2011 | 08:21 AM
Daz00Excursion's Avatar
Daz00Excursion
My Backpack Gots Jets
is it 4x4? or 2WD? first thing i would look into is the shocks.
Old Sep 26, 2011 | 09:06 AM
Joe28443's Avatar
Joe28443
Joe28443
Sorry I done ut rom my dumb phone and my sig does not show up.
2001 Ex 2wd diesel and I have a rancho xl9000 installed about 5 months ago
Old Sep 26, 2011 | 09:17 AM
Daz00Excursion
check out this thread....
https://www.ford-trucks.com/forums/9...n-upgrade.html
Old Sep 26, 2011 | 02:37 PM
hhcobra's Avatar
hhcobra
What setting are you running your shocks at? I've got mine on three and it has a decent ride. It's no Cadillac though!!!
Old Sep 26, 2011 | 08:30 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
My ride was greatly improved when i swapped out for new springs, you should notice a huge difference. My was a lot better with the heavier springs. Mine @ 80k were sagging & bottoming out, great mod idea
Old Sep 26, 2011 | 09:00 PM
Joe28443's Avatar
Joe28443
Joe28443
Curt is yours 2 or 4wd? I have ridden in an ex with 200k and 4wd and it rode and drove alot better than mine. Mine about jars you to death on the smallest bump. I was curious about the stiffness over the stock springs changing over to the 350 springs. Will I have to swap out my shocks? Will there be enough movement on my 2wd shocks? Thanks for the advice.
Old Sep 27, 2011 | 10:40 AM
jdadamsjr's Avatar
jdadamsjr
What tires and air pressure ?
load range E and 80 psi will not care WHAT springs/ shocks you have on it
I dropped my psi and it rides smooth
Old Sep 27, 2011 | 11:27 AM
Joe28443's Avatar
Joe28443
Joe28443
I will have to check it out when I get home. Its not 80 though, what are you running?
Old Sep 27, 2011 | 03:58 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1
Same here I lowered the pressure in the front from 65 to 52. Huge difference.
Old Sep 27, 2011 | 04:25 PM
jdadamsjr's Avatar
jdadamsjr
If towing heavy you should have enough air pressure to get to the load carrying capacity of the tires....
lower air means lower weight carrying capacity.... I run about 55.... sometimes lower around town...
Do a search for the chalk test, that let's you know the best pressure for your tire/turck combo... good luck...
Old Sep 27, 2011 | 07:30 PM
Joe28443's Avatar
Joe28443
Joe28443
I'm sure there is around 70 in them. I have not adjusted since I towed my camper, which I just sold last week. I will adjust to 55-60 and check it out.
Old Sep 27, 2011 | 08:21 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Mine is 4wd i run my tires @ 65 psi unless im towing over 5k. I was able to use my stock rs 9000 shocks, but i have ras in the back
Old Oct 1, 2011 | 08:17 AM
Joe28443's Avatar
Joe28443
Joe28443
Wel I checked tire pressure and it was 60 all around. My wife and I just go back home after a trip out and she said she is about tired of the constant jarring she feels while riding in this truck. She said it did not ride like this when we got it. And she is rght. I was all about trying to get new springs and such and then I thought about it.I had chenged fro Michelins to Firestne AT's about year ago. And also intalled a sway bar. Do I really need a swaybar on a 2wd truck?? I do tow a TT with it sometimes. I just bught one because everybody else had one. My wife says you need to do something about this ride!! My dillema is do I change out the springs?? Changing to truck springs to me makes me tink of a harsher ride. Ditch the sway bar? I just dont want to spend a ton on changing out springs and it not help he problem. Anybody out there with a 2wd Ex let me know yor set up. tires, springs, shocks etc. Thanks
Old Oct 1, 2011 | 10:31 AM
Peace2Peep's Avatar
Peace2Peep
Dude that sounds like shocks too firm...springs should get softer over time.
