transmission noise
Old Sep 25, 2011 | 06:24 PM
mwkobe's Avatar
mwkobe
transmission noise
2002 mountaineer i have a what i believe is a transmission noise the od light flashed and went out if im in drive at a stop sign i hear a weird noise almost like water flowing thru a valve partially open.
Any thought would be great
Wayne
Old Sep 25, 2011 | 09:17 PM
mwkobe's Avatar
mwkobe
thru a web search i found the following info let me know what you guys thinks
Ford Servo Bore Transmission Fix Solution - Ford Lincoln Mercury Explorer Mountaineer Navigator Servo Bore Fix
Old Sep 26, 2011 | 07:41 AM
tomw's Avatar
tomw
You'd likely get better response in the transmission section further down the page. A transmission will produce whining noises for hydraulic leaks. I've never heard a leaking valve type noise.
The fix noted above would be used where the servos would try to contract the band and the band would slip. Most times there would be no noise, just the engine rpms increasing and the vehicle not moving, or moving slowly, or shifting into 'neutral' instead of another gear.
tom
Old Sep 26, 2011 | 11:31 AM
mwkobe's Avatar
mwkobe
thanks i never new about the transmission area of this forum
wayne
jermort
6.7L Power Stroke Diesel
104
Jan 6, 2017 10:45 AM
caprisecca
Jun 28, 2013 02:47 PM
ThirdsACharm
EcoBoost (all engine sizes)
Nov 15, 2011 07:18 PM
verticalrich
Nov 19, 2006 12:05 PM
