Trans Filter for ZF 6
Old Sep 25, 2011 | 05:43 PM
Visseroth's Avatar
Visseroth
So I'm getting ready to install my filter on my 6 speed but I wanted to know how you guys connected your filters. Which line is the input and output on the trannie? Does anyone have any pictures of their installation and the connections to and from the trannie? I'd like to see the pictures.
Old Sep 25, 2011 | 06:53 PM
timmyboy76's Avatar
timmyboy76
Old Sep 25, 2011 | 07:05 PM
Visseroth's Avatar
Visseroth
Ahh, just what I needed to know, thank you and that is the kit I'm working on installing, I'll post how it goes
Old Sep 25, 2011 | 07:39 PM
Visseroth's Avatar
Visseroth
Has anyone else tried blowing out the cooler line during install?
Old Sep 25, 2011 | 11:25 PM
timmyboy76's Avatar
timmyboy76
Yeah, Vis, post up pics and how it went. I've got a 6spd, and been wanting to do this "mod", but a DIY one though.
Old Sep 26, 2011 | 08:37 AM
mueckster's Avatar
mueckster
This how we plumbed the inline filter on Barney's (bfife) truck when we installed the DS kit, using the fittings and hoses provided.
Old Sep 26, 2011 | 09:09 AM
Kwikkordead's Avatar
Kwikkordead
That's a very nice setup there, Roland.
Old Sep 26, 2011 | 04:23 PM
Fat Diesel's Avatar
Fat Diesel
Here's uh my post in your thread!
https://www.ford-trucks.com/forums/8...tration-3.html
Old Sep 26, 2011 | 08:27 PM
Visseroth's Avatar
Visseroth
I like the last posted pictures in that link much better than my own, lol.
So what is your idle PSI? once mine is warmed up mine seems to idle at about 10psi. When it's cold it goes into the red and I can hear the bypass valve letting the fluid pass by. It seems to humm a little with a slight squeal. But like I said once it's warmed up the pressure drops down and the noise stops.
I'll be posting pictures tonight when I get back under the truck to finish topping off the trannie.
Old Sep 26, 2011 | 10:18 PM
bfife's Avatar
bfife
still plays with trucks
I didn't put a pressure guage on mine. I just plan on changing the filter once a year. which will be somewhere around 30k. i did put a temp sensor in my tranny and was please to see it run about 50 degrees above ambient temp pulling 18k. whats nice about the manual tranny is the temp will drop 10-15 degrees if you let it idle for 5 minutes.
Barney
Old Sep 26, 2011 | 11:27 PM
scottnchrissy's Avatar
scottnchrissy
So is this more of a bypass filter or full flow? Does the filter base need a pressure bypass? What filter number was included with the kit? I would like to make my own kit and save a few bucks.
Old Sep 28, 2011 | 12:02 AM
Visseroth's Avatar
Visseroth
I don't have the filter number ATM because I have been very busy but the filter kit has a built in bypass if the pressure gets to high, ie a full filter. None the less a filer is a really good idea since the stock manuals don't have a filter, I don't know if the autos have a filter or not. None the less, moving parts and gears means wear, wear means debris and debris needs to be removed to increase reliability and life expectancy.
Old Apr 5, 2016 | 03:25 PM
Syncrowave's Avatar
Syncrowave
Interesting setups.
Question: Is there much to be gained by adding a filter to a ZF6 650? Do they get much crud suspended in the ATF that doesn't get grabbed by the bung magnet?
Also, is the ATF pump strong enough push it through the filter (I guess it's just a positive displacement gear pump so I guess yes)?
Thank you. This site is a great resource. Seems like whenever I Google anything for my SD, this site comes up first.
Old Apr 5, 2016 | 07:33 PM
F350-6's Avatar
F350-6
Kind of an old thread so you may not get too many responses.
I don't have a filter on my ZF-6. I change the fluid every 50k miles and it always comes out looking new. I've got 540,000 plus miles on it currently with no rebuild or repairs. I'll change it again when it hits 550k.
Old Apr 5, 2016 | 07:36 PM
CampSpringsJohn's Avatar
CampSpringsJohn
You know Chris, if you didn't keep that truck in the garage all the time, you might put a few miles on it!
