Front end help
Old Sep 30, 2011 | 10:02 PM
ct50f1's Avatar
ct50f1
Originally Posted by tinman52
1/8" toe should be fine. I'd bet your axle needs to be tipped back a little more. Did they check or set the caster? Most shops either don't know how or are too lazy to change the caster on a beam axle.....
Is the addition of the wedges to adjust castor only needed if you're running a drop axle or would it improve handling if you were running a stock axle? If I've read this and other threads about castor adjustment shims correctly, it's only needed with the drop axle.
Old Sep 30, 2011 | 10:28 PM
dongc1's Avatar
dongc1
The factory had castor shims on the stock front axle. They were 2 deg. At the higher speeds we drive today, more is better. 4-6 degrees is good on a stock axle.
Old Oct 1, 2011 | 06:31 AM
ct50f1's Avatar
ct50f1
Thanks Don. I'll look into getting some. I don't remember there being any shims there when I tool the truck apart.
Old Oct 1, 2011 | 10:41 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I'd try adjusting the toe-in a little more
Bobby
Old Oct 1, 2011 | 11:49 AM
49willard's Avatar
49willard
My only comment would be that as you add more caster the original trucks become more "armstrong". If you have power steering (a modified setup) it does not really make a steering effort difference.
Old Oct 1, 2011 | 09:53 PM
ct50f1's Avatar
ct50f1
Since I'm going with a stock front end I was going to try and find either 2 or 4 degree wedges. Does anyone know where to get them? I can't find any in the catalogs I have.
PS - How are things in Harpswell? We enjoyed a weeks vacation there at Card Cove this summer.
Old Oct 1, 2011 | 10:21 PM
Mervy49's Avatar
Mervy49
You might be able to get those shims at your local
Napa Store. The Napa dealer here has them in stock.
jaye
Jun 8, 2008 10:54 AM
sturoe
Feb 14, 2008 07:30 AM
BFOOTER03
Sep 28, 2007 09:07 AM
imlowr2
Aug 14, 2007 11:16 PM
