Brake drums stuck
Old Sep 24, 2011 | 04:00 PM
Pennypincher's Avatar
Pennypincher
Red face Brake drums stuck
I can not get the front brake drums off my '47 toner. The manual shows the adjustment bolts at the bottom of wheel but the front looks like rivets. The back wheels look like what is in the manual. This is a barn find truck that has been setting for over 25 years. We cleaned up the fluids, replaced the master brake cylinder and we could not get the front drum off to replace the wheel cylinders. When the brakes pumped up after installing the master cylinder we put some gas in her. After a few tries she cranked right up so we took her for a slow ride. After grinding a few gears she blow the front wheel cylinder so now we have to get it off. My son and I are trying to decide if we should keep her all natural of do a frame off. She is complete right down to the hand crank. So i'm sure we will be asking alot of questions. Thanks in advance for the help and suggestions.
Old Sep 25, 2011 | 07:44 AM
38 coupe's Avatar
38 coupe
Can you post pictures of the back of the backing plate?
Old Sep 25, 2011 | 08:24 AM
raytasch's Avatar
raytasch
Believe Nothing
Pictures will help determine what you have if anything other than the normal. Sometimes it is necessary to do a bit of destructive disassembly on these old units, cut bolts, etc.
In deciding what to do with the old truck, remember they are only original once. Not that a restoration is a bad thing.
Old Sep 25, 2011 | 10:43 AM
Pennypincher
Will try to post pictures shortly. Truck is at son's house.
Old Sep 29, 2011 | 02:09 PM
Pennypincher
Got the pictures let's see if can get them uploaded
Old Sep 29, 2011 | 03:04 PM
Pennypincher
Got the pictures uploaded under my Mader folder. I could not attach to this reply. I need to learn how to do that?
Old Sep 29, 2011 | 03:50 PM
Pennypincher
got the driver's side drum off. Now I know how they were installed. One issue down but now I need to find some brake shoes and possibly a couple of drums. nothing available from normal parts stores. Anyone know of a source?
thanks
Old Sep 30, 2011 | 07:16 AM
petey shoes's Avatar
petey shoes
try job-lot in queens, ny. for drums. you might even be able to have them cut. as for shoes--any reputable heavy truck brake shop should be able to re-line them. ask your local jobber, (napa, etc.), they can tell you who does this in your area.
Old Oct 2, 2011 | 05:26 PM
Pennypincher
Thanks Petey shoes
I'll check with top job and with my local NAPA store.
Any thoughts about changing over to disc brakes, I keep seeing adds about kits that fit the exsisting spindles? Would that require all new brakelines or just the master cylinder? I have so much to learn about these trucks and so little time??
47 Flatbed and 47 Tonner.
runawayhound
Dec 7, 2015 08:56 AM
Robhudson
Jul 4, 2015 12:50 AM
tbm3fan
15
Dec 18, 2006 02:45 AM
mick460
Garage & Workshop
17
May 2, 2004 08:08 PM
Papas Ford Girl
Aug 25, 2002 01:08 AM
