brake lines suck!
Old Sep 23, 2011 | 11:39 PM
ChristopherN's Avatar
ChristopherN
brake lines suck!
So, I am in the midst of replacing the wheel cylinders in drum braking system and I broke the rusty brake line, I figured no problem, get a replacement.
Turns out that it seems there's different size fittings on each of the where the brake line goes in.
What I mean is, the wheel cylinder fits a 10mm thread no problem but, that device that splits the fluid between the two sides of the truck is a much bigger thread/nut thing.
Can someone give me full specs on the rear brake lines, sizing and all that? I really need help, I tried looking in my Chiltons and I couldn't find the brake line sizing. I need help because I need this truck to work by sunday afternoon. I stopped for the night as it's 11:30pm.
Old Sep 24, 2011 | 03:27 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Ford uses a different sized nut on -either side- of that splitter.
The 7/16-24 on the drivers side is the oddball size, I believe. I can check mine in the daylight.
Old Sep 24, 2011 | 06:12 AM
tjc transport's Avatar
tjc transport
i ain't rite
ChristopherN posted: "brake lines suck!"
no sir, your statement is incorrect.
vacuum line suck.
brake lines blow!!
Old Sep 24, 2011 | 07:02 AM
Nealcrenshaw's Avatar
Nealcrenshaw
You need a couple brake line adapters,they're at your local auto part store.
berry1234
13
May 2, 2016 03:35 PM
wheelieking
Jan 5, 2015 12:20 PM
DBKER31
1997 - 2003 F150
May 3, 2009 08:59 PM
mitch150
General Automotive Discussion
Nov 10, 2007 05:14 AM
