Fuel Injector Pump question
Old Sep 22, 2011 | 10:17 PM
henslee's Avatar
henslee
So as the story goes, i got a new fuel injector pump for my truck because the old one went bad. One question i have is; can i replace it myself without screwing up the timing, or will i have to have a friend that is diesel savvy come do it for me? Also, is there anyway i could find out the timing setup and do it myself correctly?
Old Sep 23, 2011 | 06:47 PM
Franklin2's Avatar
Franklin2
Do lots of research and searching on the various diesel websites. And you will eventually need to get it timed with a special meter. From what I have read, the most important part is to make sure to leave the gear that drives the pump in place, so you will not mess up the timing. I believe people leave the housing on, so it keeps the gear in place. If the gear gets out of place, you are in for a headache.
Old Sep 24, 2011 | 02:30 PM
henslee's Avatar
henslee
ok sounds good. found out that as long as i can get the pump on and if i manage to screw up timing, a shop will time it for $80
Eric Kropp
Jul 29, 2014 10:49 PM
Jerry's red Ford
Feb 17, 2014 02:59 AM
mightyhammer0321
18
Oct 13, 2008 10:35 PM
Katmandu
Nov 29, 2005 08:07 PM
Jisa
Jan 3, 2004 07:19 PM
