Had some Codes pop up Today,,,
Old Sep 22, 2011 | 06:39 PM
m350's Avatar
m350
Leaving work today,,AC on,,truck running fine,,,Blip,,,on comes the "Engine" light in the Dash,,,then my Edge Insight Gauge setup start's changing colors and Blinking,,,Flashing "5 Diagnostic Codes", never did see that before, so my son grabs the Edge Insight, and does the Diagnostics to retrive the codes,,
Injector's #1 & #2 low voltage
C1501
P1555
C1555
B2:2
I have looked thru the Diag. Codes in the tech folder only found the P1555 code??
Anybody have any more info on these codes ??
The truck ran great the whole time,,,cleared the codes after,,,"Engine" light stayed off on my way home.,,,,Thanks,,,Mark
Old Sep 22, 2011 | 07:04 PM
2006powerstroke90's Avatar
2006powerstroke90
Check all connections to FICM including the ground.
Then test the FICM.
https://www.ford-trucks.com/forums/8...procedure.html
Old Sep 22, 2011 | 07:32 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Man, I did some looking around and this was the only thing I could find. Now, is this a true Description of C1501?. I can't say.
C1501:
C1501 Transfer Case Contact Plate "C" Encoder Circuit Failure
Old Sep 23, 2011 | 04:58 AM
npccpartsman's Avatar
npccpartsman
C1501
P1555
C1555
B2:2
AE lists P1555 as an injector circuit code for #5. C1501 is a transfer case code. The other 2 are listed as unknown. I would clear the codes and see if they return but with 3 low injector codes I'm suspecting FICM also. I have no knowledge what the transfer case code means but someone here will know.
Old Sep 23, 2011 | 10:15 PM
m350's Avatar
m350
OK guys thanks for the info,,,I did clear the codes with my Edge Insight,,,and all was well today,,,It threw a couple codes about 4-6 months ago too,,,was something about Injectors then,,,but the truck has run good,,,now and then when leaving in the am,,it has skipped and taken off slower,,,,I will do a FICM voltage check soon,,,looked at the tech article,,,plus found a video on youtube about it.
That C1501 code is strange,,,seeing as I have the manual Hubs and transfere case !! Not sure what that code would be about ??
Old Sep 27, 2011 | 08:02 AM
m350's Avatar
m350
Ok guys checked the voltage, the voltage recorder with the key on was 46.2, the truck cranked over with 47.5 volts and held at 48.6 to 49.1, yesterday truck threw codes, #3 and #6 injector low. Whats the next step now. Thanks....mark
Old Sep 27, 2011 | 03:08 PM
m350's Avatar
m350
OK ,,so we did the ficm voltage check this am,,truck coolas indicated above(my son entered the info with his I-Pad),,with key on,,at first it was down to 20.5 volts or so,(Glow Plugs on ?),then jumped up to 46.2after a few seconds,,,tried cranking it,,(truck started) got 47.5 volts,,,then running up too, 48.6 to 49.1 volts,,so I take this as my FICM is still ok at this point,,,any thoughts ??
Now yesterday it through codes #3 & #6 Injector circut low,,,,cleared them using the Edge Insight,,,,after the truck sat 2-3 hours or so,,fired it up to go home,,,,the truck through 8 codes,,,,still running fine,,,here they are
P0261, #1 Injecter circut low
P0264, #2 Injector circut low
C1501, unkown
P1555, unkown
P1555, unkown
B2:2:: unkown
P1112, IAT circut Intermittent fault
P0055, (H02S) Heater Resistance (Bank 1 sensor 3),,,any thoughts on what may be going on here??
Seems to set off codes now when the truck has cooled off some, setting a couple hrs,,starting in the morning, and so on,,,thanks for any info,,,,Mark
Old Sep 27, 2011 | 03:18 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Up in to READ ME FIRST posts are the instructions for how to pull the FICM and re-solder some connections..... try that and see if your voltages return to normal...esp at key on:engine off and :start.
Old Sep 27, 2011 | 03:23 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Truck still runnin ok? I would clear codes and continue to monitor. Seems pretty random. 20v at the FICM may be a tell even it's only a couple seconds. Might point to a power (or ground) issue but I would think FICM is ok right now. Good luck! Sounds like this one could be a booger.
Old Sep 27, 2011 | 03:27 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
I would NOT trust a 20v signal...... re-solder the FICM.
Old Sep 27, 2011 | 04:39 PM
npccpartsman
Anything under 45V indicates a faulty FICM, especially with two low circuit codes. I would, however, have the batteries load tested (separated from each other) before I jumped to any conclusions. Also, check ALL your battery cable connections--battery, frame, block--and make sure they are clean and well connected. I'm attaching the TSB for the correct procedure to test the FICM.
File Type: pdf
Old Sep 27, 2011 | 05:18 PM
m350's Avatar
m350
Yes the truck runs Good,,,a little slower in the am,,,but warm is like normal,,,No smoke, truck starts good,,No rough running lately,,,it has skipped some in the am,, twice on take off.
Now in the FICM Guide (Tech section),,,one guy mentions to remove the GPCM (Glow plug control Module) from the drivers side battery,,to reduce battery drain,,,,I did not do this,,,and was thinking this was possibly why it was at 20.5 volts for a few seconds when testing the FICM ?,,it went upto the 46.2 after the buzzing(glow plugs, maybe fuel pump) stopped.,Has anyone removed this GPCM before testing the FICM ??
Will check Batteries and Grounds out soon!!,,thanks for any info,,,,Mark
Old Sep 28, 2011 | 05:57 AM
npccpartsman
Exactly why I posted the TSB for you to follow, however, IIRC, it also says that you must command the EOT sensor to a specific temperature but I don't know how you'd accomplish that in a home setting. I'm still saying your FICM is bad and needs repaired. Mine never falls under 46.5 with a full load on it, including glow plugs, at start up.
Old Sep 28, 2011 | 08:33 AM
lray's Avatar
lray
need to replace my alternator ,also engine light blipped on ! Is this related?
Old Sep 28, 2011 | 03:42 PM
npccpartsman
Possibly. Since your in California with an 03 truck you'll get a CEL for things other trucks won't. It would be helpful to have the truck code scaned to make sure you haven't damaged critical components from running low voltage.
