Sponsored by: Real Truck
Calipers?
Old Sep 22, 2011 | 12:15 AM
kbf1961's Avatar
kbf1961
Calipers?
I need to do the brakes on my 2006 F-350 4x4. Are the OEM calipers on this rig worth keeping? Once upon a time I had a 89 f-250 and the oem calipers were junk. Is that also the case on the 2006?
Old Sep 22, 2011 | 01:27 AM
The Metal Panda's Avatar
The Metal Panda
I think a 17 year difference is a pretty big improvement window. lol Im sure your calipers are just fine. Why would you replace em if they werent broke? Unless you NEED better stopping abilities. But im sure brakes on a 350 are pretty damn good..
Old Sep 22, 2011 | 12:39 PM
jonsk's Avatar
jonsk
I have had all of mine replaced by ford 3 times because they keep seizing up. I have looked for better ones but have not been able to find aftermarket replacements. That is one of the only problems that i have had with my 06.
Old Sep 22, 2011 | 11:29 PM
kbf1961's Avatar
kbf1961
[quote=The Metal Panda;10837249]I think a 17 year difference is a pretty big improvement window. lol Im sure your calipers are just fine. Why would you replace em if they werent broke? Unless you NEED better stopping abilities. But im sure brakes on a 350 are pretty damn good..[/quote
Metal Panda, Do your home work or youll be walking
Old Sep 22, 2011 | 11:31 PM
kbf1961's Avatar
kbf1961
Jonsk, Thanks that is what happened with the 89 I had. I replaced with an aftermarket equivilant and it was the end of the problem
Old Sep 22, 2011 | 11:40 PM
The Metal Panda
Oh god.. are ford brakes known for seizing or something?
Old Sep 23, 2011 | 02:15 AM
hotroddsl's Avatar
hotroddsl
Maintain the slide pin rubbers and lubricate the pins and ways as recommended and flush your brake fluid! And yours will provide hundreds of thousands of miles of trouble free service! Over the past 13 years I have had 0 brake issues on my personal trucks! I can't say the same for my friends and customers who did not follow Fords instructions on this simple guide to maintenance!
Jim & fat Monty
Old Sep 23, 2011 | 11:09 AM
raidscsi's Avatar
raidscsi
The slides on mine were completely dry of grease, some loose and rusty some locked up stiff and rusty. Grease the slides, and as long as the cylinders move in and out freely keep the OEM.
There are a few auctions on eBay for rotor/caliper/caliper bracket/pads/slides/shims/boots for a ridiculously low number. Next time I do brakes I'g going to replace it all as the lower cylinder in the passenger side caliper is a little stiff.
Old Sep 23, 2011 | 02:02 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I JUST finished replacing my front rotors/pads. Those SD calipers look SD too! Keep the stock ones unless you have a problem.
biglsells
Oct 25, 2016 07:05 PM
cm1seabeusn
Nov 29, 2012 12:52 PM
shuttlevalve
Nov 27, 2009 04:09 PM
Aquageist
Oct 29, 2009 06:15 PM
jsikora
Jan 27, 2007 12:12 AM
