Oil & Lubrication
filter shelf life
Old Sep 21, 2011 | 08:51 PM
dagren99's Avatar
dagren99
filter shelf life
Cleaned the shop up today -- needed it. Found a "forgotten" case of FL1995 filters that had fallen behind a cabinet. The date code on the case is from 2004.
Use 'em or toss 'em?
I've used filters that were a year or two old but not 7!
Old Sep 22, 2011 | 01:30 AM
tbm3fan's Avatar
tbm3fan
Use them as we are not talking about 16 oz. jars of Skippy peanut butter.
Old Sep 22, 2011 | 06:29 AM
dagren99's Avatar
dagren99
I was just thinking that maybe the filter materials may degrade w time. Usually we buy a case of filters and they're gone within 6-9 months.
Old Sep 22, 2011 | 07:02 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Unless they got wet, they're fine.
Old Sep 22, 2011 | 07:46 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
As long as the rubber seal isn't cracked and hard(which I doubt) don't see an issue.
Old Sep 23, 2011 | 06:42 AM
pawpaw's Avatar
pawpaw
If the filters have been stored in their origional packing containers, in an air conditioned space, with low exposure to humidity, ozone & temperature extreems, the inner components should be ok. Maybe open a box & have a look at the base rubber gasket seal & anti-drainback valve for condition & the unfinished inner metal parts for signs of rust.
Old Sep 23, 2011 | 06:53 AM
dagren99's Avatar
dagren99
I wouldn't call our shop "air conditioned" unless wide open doors count
That was my original concern when I posted - not so much the time but I don't think I'd say they were stored under "controlled" conditions. They appear fine, no rust etc. The other part of this is they will likely sit yet another 4-5 months as we don't have any trucks currently in need of an oil change. I may just toss them.
Old Sep 23, 2011 | 07:14 AM
pawpaw's Avatar
pawpaw
Maybe consider a phone call to the mfgr, give them the details you've posred here & see what they have to say.
Old Sep 23, 2011 | 07:24 AM
dagren99's Avatar
dagren99
That would be Ford..... Well whoever's making their filters (FL1995) these days. Doubt they'd sign up to anything. We prob payed around 8 dol per filter so it's roughly a hundred bucks I'd be tossing.
Old Sep 23, 2011 | 09:06 AM
pawpaw's Avatar
pawpaw
Well if you can't find out anything from the distributor, or Motorcraft, maybe consider offering them on special at cost, at least you'd be recovering what you now have in the filters.
It's thought that Purolator makes the aftermarket Motorcraft filter.
Old Sep 23, 2011 | 02:56 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Just use the danged things......
Old Sep 23, 2011 | 04:41 PM
tbm3fan's Avatar
tbm3fan
Old Oct 2, 2011 | 10:09 PM
qwikford's Avatar
qwikford
I've run filters from the late 90's that I found in my closet, without anything fouling up or going BOOM, so I'd say go ahead and use them. Any major problems and you'd see them while you were putting the things in.
pyro2nite
6.4L Power Stroke Diesel
Jul 10, 2011 10:46 PM
snakedoc
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Mar 4, 2011 09:11 PM
89Flivver
Oil & Lubrication
Feb 28, 2008 03:51 PM
Swift193
May 25, 2007 11:10 AM
Pilgrim
Oil & Lubrication
21
Jan 19, 2004 07:33 AM
