running hot and thin
Old Sep 21, 2011 | 06:02 PM
beardshadow's Avatar
beardshadow
Hey guys,
Truck running hot (still in normal range but upper ½) and oil pressure drops to below normal when all warmed up and at idle (pressure good when driving).
Related???
Newer coolant and thermostat is working... lazy water pump??
Any ideas?
Thanks!
Old Sep 21, 2011 | 07:21 PM
i-w's Avatar
i-w
when hot check lower rad hose. the pump might be able to suck it in to collapse the
hose.
does the lower hose have a wire spring in it? it should help the lower hose keep from
collapsing in.
just a thought.
when engine is at temp feel the radiator for cold spots. well not even temp across the
core. if it has hot and cool or warm spots the radiator core could be clogged in spots.
if it is the stock radiator it can get calcium type build up and clog the coolant flow
from top to bottom of radiator. causing the hot or cold spots.
Old Sep 21, 2011 | 09:15 PM
montana_highboy's Avatar
montana_highboy
You really need to install a set of aftermarket gauges to accurately monitor the engines vitals, in all honesty the factory gauges are pretty much worthless for anything other than a "guesstimate" of actual engine conditions.
Old Sep 22, 2011 | 06:59 AM
i-w's Avatar
i-w
i agree. get a quality water temp gauge.
Montync
Oct 7, 2015 02:39 PM
capriceragtop
28
Dec 7, 2012 10:00 AM
Scratcher
Nov 20, 2010 05:10 AM
heybrent
1978 - 1996 Big Bronco
Sep 16, 2003 12:07 AM
chrismenken
Nov 28, 2001 07:45 PM
