EGR Valve disconected
Old Sep 21, 2011 | 02:41 PM
kjackson's Avatar
kjackson
After my truck lost all power and blew black smoke out the exhaust then cleared up and ran fine for anoter 600mi before doing it again i was able to locate a Ford garage,when they checked for troublecodes none were shown. They had no idea what happened,so after reading the tech bulitens I pulled the plug to the EGR valve. I am now home after 2000 mi of no trouble and a better running truck. Am I hurting anything with this disconected or should I clean and reconect the EGR valve. This in a 2004.
Old Sep 21, 2011 | 02:48 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
you aren't hurting anything. sounds like your EGR is sticking...and/or you have a clogged cooler
03/04 (without new PCM strategies) trucks can unplug/remove the EGR and no problems. 05+ trucks have to get a tuner to remove the CEL.
Do you have gauges to check EOT and EGR cooler temp?
Old Sep 21, 2011 | 03:18 PM
kjackson's Avatar
kjackson
No I do not have any seperate gauges but will get to the auto parts store to see what they have that I can use.
Old Sep 21, 2011 | 03:43 PM
smokersteve's Avatar
smokersteve
my buddy has an 03 dually and he unplugged the egr valve and noticed a much better running truck. He only has 40,000miles on it.
My tuning turns it off on my truck.
silverbullet6oh
Apr 17, 2015 07:09 AM
sniggly
Dec 27, 2011 04:50 PM
gearloose1
Jan 2, 2011 09:18 AM
viperrtblck
6.4L Power Stroke Diesel
Mar 13, 2010 06:59 AM
clinter36
Sep 11, 2008 02:50 PM
