I am trying to find some of the plastic clamp assembly that holds the fuel lines, evaporative line and brake line on a 90 F250 w/460 engine. The fuel and evaporative lines are in a triangular bundle at least as far forward as the front side of the midship fuel tank. The clamp latches over that bundle and has a pin that pushes through the frame rail. Below the plastic tube bundle is a clip the brake line snaps into. Forward of the back edge of the cab is a different clip since the evaporative line goes across the frame cross member there.
If any one, numberdummy included, has a source for them it would be great.
Actually, the part # you need is N802770-S
It is still available from Ford, but they only sell 'em in packages of 8
However, the Ford dealers in Woodstock VA & Harrisonburg VA both show that part in stock.
I got the bag of 8 N802770-S retainers from Wynne Ford yesterday. Nice, but these are the three line, one above the other used on the front portion of the lines and are the same ones my 86 had for all the fuel and broke line retainers. The ones I need are 3 hard plastic probably 3/8" lines in a bundle, held in with a latching clamp and a single smaller clip below for a brake line. I can still use these on the front portion ahead of the side tank to the fuel line bracket.
Ok, here is a picture of the two clips. The left one is the type I am trying to find. The spot in the middle of the two furthest apart ribs is supposed to be a "Christmas tree" like the right one, N802770-S. The rear portion of the fuel and vapor lines run through the top section and the rear brake line runs through the bottom clip.
