1999 PSD Hpop ?
Old Sep 22, 2011 | 06:46 PM
ggirten's Avatar
ggirten
This is good information. I wish I had it when I started checking my truck.
On mine, I went through all the normal testing and replacing, but it was definitely the HPOP. I replaced the IPR, ICP, injectors (because my son had a good set), LPOP, new O'rings throughout the oil system and fuel bowl. While it is rare, it does happen and did with me.
Old Sep 22, 2011 | 08:56 PM
Oldsmoky92's Avatar
Oldsmoky92
Hey that is worth a try! And once again i really appriciated all the input guys! I am new to the powerstroke but am capable. I read through the post, very helpfull information! Tomorow i will try the snapon scan tool and hopefully get a reading, but i will pull the IPR out and clean it! Thanks.
Old Sep 22, 2011 | 09:57 PM
caverjoe's Avatar
caverjoe
I am sure there is a post on how to clean that IPR but if I remember right one of the pieces was kinda tricky to get apart. Some small pieces also. Just a heads up.
Old Sep 23, 2011 | 12:13 AM
BigAlsPSD's Avatar
BigAlsPSD
Here's info for the IPR rebuild/cleaning.
IPR Rebuild - Large Pics.pdf
Old Sep 23, 2011 | 10:06 AM
Oldsmoky92's Avatar
Oldsmoky92
I am going to work on the pickup after work today and i will post my findings. Thanks.
Old Sep 23, 2011 | 02:23 PM
Oldsmoky92's Avatar
Oldsmoky92
Well scanned the rig hears what i got. ICP (v) 3.00 +-, ICP psi 2,000., IPR %40, Fuel lvl inp (v) 0, %0. I hope there is somethin to give an idea.
Old Sep 23, 2011 | 02:36 PM
BigAlsPSD's Avatar
BigAlsPSD
Is this while cranking? If so do you get any smoke while cranking?
Old Sep 23, 2011 | 02:47 PM
ggirten's Avatar
ggirten
What is Fuel lvl inp? Fuel level input? You may have a fuel issue rather than an oil issue.
Old Sep 23, 2011 | 02:52 PM
BigAlsPSD's Avatar
BigAlsPSD
Fuel level is not monitored by the PCM if I remember correctly, so no worries about the PID, however, I'm not sure if it was asked, do you get the WTS light and hear the fuel pump running with the Key on?
Old Sep 23, 2011 | 03:25 PM
Bonanza35's Avatar
Bonanza35
[quote=BigAlsPSD;10841713]Here's info for the IPR rebuild/cleaning.
Attachment 41719[/quote
Question Alan. Do you actically put the pipe wrench on the threads? It looks like the tube unscrews from the threads.
Chet
Old Sep 23, 2011 | 04:04 PM
Oldsmoky92's Avatar
Oldsmoky92
Yes this is while craking. Well i havent even noticed the WTS light and i havent listened for fuel pump, I will check though. And i havent noticed any smoke, the rig is parked in tall weeds and has wide service bed on it, cant really see much but i will check.
Old Sep 23, 2011 | 06:56 PM
BigAlsPSD's Avatar
BigAlsPSD
[QUOTE=Bonanza35;10843721]
Chet
I do not, and that write up was just for picture purposes, I remove it on the unthreaded portion personally with a stud remover on a ratchet.
Old Sep 23, 2011 | 07:56 PM
  #28
Oldsmoky92's Avatar
Oldsmoky92
Well i took the IPR out, it looked fine no pieces or goo. I took what i believe is the return lies off of the fuel bowl and nothing comes out when i crank. I Cant figure out where the feed lines even go in though. ON th my 95 they go in the front of the head and the returns come out the back. All i can find are the return lines on the pass side and the in and out on drivers side of fuel bowl. So my question is now where are the feed lines ?
Old Sep 23, 2011 | 08:36 PM
  #29
Bonanza35's Avatar
Bonanza35
Oldsmokey92, the outlet fuel lines to the heads are on the passenger side (2). The top outlet or return line is on top drivers side and the feed line is below that on drivers side. If you have know fuel out the passengers side the fuel pump isn't working or you are blocked in the bowl I would think. Open the drain line, turn the key on and see if it flows out the bottom, if not your fuel pump is most likely bad. It could also be blocked in the tank. You should be able to hear the pump running even if you have to get under the truck if its blocked. Good luck Chet
Old Sep 23, 2011 | 09:17 PM
  #30
Oldsmoky92's Avatar
Oldsmoky92
Well i took the filter out and turned key on and it immediatly began filling with fuel, i put my finger over the source and i could not stop the flow. So i guess i need to make sure i am getting fuel into the heads and also have sufficent oil pressure at heads. Is there a selenoid or something that lets fuel pass into the head? Or if the IPR is stuck could that be keeping the oil from getting out of hpop and into supply lines? I also did a buzz test and all injectors were audibly equal. Im not getting frustrated just getting more intersted in finding the problem. Thanks, Chad.
