No radio
Old Sep 19, 2011 | 11:39 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question No radio
I was returning from the weekend and the radio, was showing the time, end suddenly shoot off the numbers and no radio or any function, only a little lite in the "****"of the little arrow of advance is on.
Any ideas, I havent check any fuses or anything yet. Just arrived and went to work. The OBD port works.
BTW I was reading in the scan gauge : 1850~ IPC and 35%~ DC, at about 1800-200 RPM and 45 MPH, its that correct?
Thanks in advance.
Old Sep 19, 2011 | 09:08 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
BUMP, BUMP.
Old Sep 19, 2011 | 11:17 PM
oldbird1965's Avatar
oldbird1965
Who needs a radio, just roll down the windows and listen to the turbo spin. No seriously, I don't know any think about the radio. Mine works and thats all I know.
The ICP and DC varies alot depending on load, etc. But what you say sounds about right.
Old Sep 19, 2011 | 11:23 PM
DDPJ's Avatar
DDPJ
Radios do just give up and die. Take it out and shoot it, that'll make ya feel better.
Old Sep 19, 2011 | 11:50 PM
pjwoolw's Avatar
pjwoolw
OEM or aftermarket Jose? Just curious.
Old Sep 20, 2011 | 08:22 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Glenn, Thank you, but I dont like the turbo spin so I put my radio noisy. LOL
Maybe some one else chime in here about the ICP and DC, it was with a 7000 pounds of load (my TT)
Good idea, thank you for the input, and what I do with the hole in the dash for the radio?
Pete Its OEM radio.
Old Sep 20, 2011 | 08:30 AM
fordpride's Avatar
fordpride
Jose if all your fuses are good and the connections behind the radio are good then I would say that it's time for a new one
Old Sep 20, 2011 | 08:43 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
You are not going to believe me but I havent had time to check the fuses, but I will soon, and yes maybe you are right, Ill need a new one.
BTW is it easy to change the radio for a new one?, do you have any special tips? and what kind or radio would be better? I know it depends of the price but I have to find one with special characteristics?
Thanks again to all.
Old Sep 21, 2011 | 09:51 AM
jtexfisher's Avatar
jtexfisher
An aftermarket radio fits very well. I pulled my AM/FM and put in a Sony CD unit. I had the Sony in a dead CIVIC, and it's all that was worth keeping after a bit of a timing belt failure.
I purchased the lil' special tools that get used to remove the Ford radio, but I'm sure there are several ways around needing them.
I also purchased a wire harness adapter. Made the Sony a plug and play after a bit of crimping and soldering.
Two more speakers from Wal-Mart for the rear and I had a 4 speaker system. The wires were already there in the rear cab corners.
The Sony cage fit the dash opening just fine, I'm quite pleased.
I'm tempted to pull the radio and try putting in a Taurus/Sable 92-95 DIN cup holder in it's place. The Crew cab, bench seat combo doesn't leave much of a way to carry coffee. And I need coffee WAY more than tunes.
Old Sep 21, 2011 | 10:00 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Harold, thank you for the input. I have a kit with the special tools, Im going to try to work with the radio maybe tomorrow or next saturday, Im going to look for a Sony CD unit. I have now a separated CD player under the middle seat.
Old Sep 21, 2011 | 02:21 PM
richdawg's Avatar
richdawg
video didn't load
Old Sep 21, 2011 | 02:27 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Originally Posted by richdawg
Rich, I cant see the pic.
Old Sep 21, 2011 | 02:33 PM
richdawg's Avatar
richdawg
<img style="visibility:hidden;width:0px;height:0px;" border=0 width=0 height=0 src="http://c.gigcount.com/wildfire/IMP/CXNID=2000002.0NXC/bT*xJmx*PTEzMTY2MzYwNDU2NTkmcHQ9MTMxNjYzNjA4OTE5Mi ZwPTIzNDQ3MSZkPSZnPTEmbz1mMWI2YWQwNzk*YWU*YTBjYmNj/OTc*NDRiNmEwYzdkMw==.gif" /> <embed width="440" height="420" type="application/x-shockwave-flash" src="http://v7.tinypic.com/player.swf?file=dbmvcn&s=7" FlashVars="gig_lt=1316636045659&gig_pt=13166360891 92&gig_g=1">
Old Sep 21, 2011 | 05:57 PM
makomark's Avatar
makomark
You can pull the unit w/o the special U clips if you are patient...two scribes, doing one side at a time will usually work fine. Nothing needed for reinstall.
Our would randomly die and then come on again when we got it. Popped it out and sprayed the connector halves with contact cleaner, reseated them a couple times, and have never had an issue yet. Based on your description (non-standard illumination pattern on the face) it may be best to find another one, especially if you like the idea of the integrated CD player.
Old Sep 21, 2011 | 08:19 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
<EMBED height=420 type=application/x-shockwave-flash width=440 src=http://v7.tinypic.com/player.swf?file=dbmvcn&s=7 FlashVars="gig_lt=1316636045659&gig_pt=13166360891 92&gig_g=1">
Very useful video, thanks.
OK I heard you. Thanks a lot.
