This is most likely a question for NumberDummy, thanks in advance.
I have installed a clark 285 in my 1970 F250 4x4, but the park brake drum on the rear is bent beyond repair, causing a vibration. I would like to replace the drum but can't find a part number on it. The transmission is out of a 1977 F700. Thanks for your help!
D3TZ-2614-A .. Brake Drum / 9" x 3" / Use with 'standard' emergency brake lever / Obsolete
Last MSRP: $327.51 / Dealer net cost: $229.26
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
COLLECTORS AUTO SUPPLY in Oroville WA has 1 = 800-414-4462.
HIGH BUCK! BOB ALLEN FORD in Overland Park KS has 8 = 800-676-0675.
VINTAGE FORD PARTS in Beaver Dam WI has 80 (!) = 877-846-8243.
No other Ford Dealer or obsolete parts vendor has any.
----------------------------------------------------- D3TZ-2614-B .. Brake Drum / 9" x 3" & 10" x 3" / Use with 'Orschein' type emergency brake lever / Obsolete
Last MSRP: $585.55 / Dealer net cost: $351.33.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
No Ford Dealer, no other obsolete parts vendor has any.
Southern California Truck Wrecking in Los Angeles CA may have both (used). Give Marty a call @ 323-587-3144.
