rear axle change
Old Apr 6, 2003 | 12:36 PM
ragingbull's Avatar
ragingbull
rear axle change
I am presently rebuilding a 1965 ford mercury 1/2 ton. I need to change the complete rear end, axle to a later 70's rear end axle with larger drum brakes.
Will one fit right in and if so what year will work.
Old Apr 6, 2003 | 09:28 PM
62stepside's Avatar
62stepside
rear axle change
I'm not positive on the Mercs but on f100s a '57 to '72 9" should be a bolt on swap. They have the same track and the '67 to '72 should have the larger drums your looking for.
I haven't swaped them, but supposedly you can also just take the brake assembly (including back plate) and bolt it on to the older axle.
Tyson
Old Apr 6, 2003 | 09:49 PM
old65's Avatar
old65
Lightbulb rear axle change
the housing mounts for the backing plates are the same- and, of course, the bolt pattern at the wheel- if you dont want to swap the entire axle, you just need everything from the backing plates out- hope this helps!-dave
f6addict
Jan 21, 2015 05:30 PM
KevVer
23
Aug 15, 2010 06:38 PM
mgf150
1997 - 2003 F150
May 29, 2010 04:03 PM
barbsbuddy
Dec 26, 2008 06:13 PM
little chucky
Mar 6, 2003 09:25 PM
