I buy K&N for the economics. One and done with an annual cleaning. In this respect it is far superior to a paper filter.
Been using them for 25+ years and have never had a SINGLE issue.
All of these claims that it lets more dirt in makes wonder if my engine will only go 299k miles instead of 300k. That is the one thing I have never seen quantified. Whoever does the test always has a bias one way or the other so I go by my own experience.
On edit, even though I did use one on my supercharged mustang I would probably not use one in a boosted engine.
I'm glad you have never had an issue....In 1997, on a brand new car (I'm talking days old) I installed a K&N oem replacement filter...oasis documented it caused (as a result of oil contamination) 2 MAF units within weeks. K&N would not honor their warranty and this was back in the day when you purchased direct from them.....even spoke with them directly at a motorsport event ( where they had their marketing trailer set-up).....just a side-steeping circus.
If Ford Motor Company wanted to use a Oil Bath Air Cleaner system wouldn't they still put them on cars and trucks?
I too my 95 Ford F-250 in for a recall (Cruise Control) had it serviced they also replaced the MAF unit. I wouldn't wish one (a K&N Filter) on my worst enemy, not even my ex-wife.
Ok, so I think that this thread clearly states that the oiled filters are not good for street applications. But what about the stock airbox? There are filters out there, like S&B, that have disposable filters. What is everyones opinion on something like that?
If you look at the published flow data, WIX HP filters flow 98+% of K&N and have a much smoother flow post filter plus excellent filtering, for a fraction of the price! I personally run either Wix or NAPA Gold.
I had a K&N drop in filter on my V10. Went to the Ocean and drove on the beach, once I returned home I checked out the air cleaner and sand had gone past the filter. From then on I have had a Motorcraft paper filter in place.
I put the full banks setup ,chip,air intake,filter,inter cooler , plenum , chip,controller , and gained 2 mpg, had power when needed pulled a 38' toy hauler weighing 20k, never once did I need to clean the air filter in 60,000 miles,I believe the are K&N, Granted this was on a 04 / Cummings d3500 4x4, 6 spd , I went from Alaska to Cali and back 3 times and all over in between , was my welding rig it weighed it at 10,800 lbs.
If you change out the stock air filter to a high flow one like the WIX, is it a good idea to unhook the neg battery connector so the truck will recalibrate to the increased airflow?
Then why do all these CAI kit instructions tell you to unhook it during installation? Is it to fool the check engine light or something?
Primarily for safety. When working under the hood, it is a good idea to disconnect the negative lead of the battery to prevent damage to electronic components and yourself.
For example - many vehicles have electric fans that can come on without warning which could lead to loose clothing getting caught or fingers being separated from their hand.
It would also prevent your "helper" from starting the engine or honking the horn while you have your head under the hood.
