Base Line Dyno run on the PRE-STROKE
what does a head stud kit cost? I wouldnt mind doing it.
oh, btw it was 8.5 degrees @ 2000rpm. my bad on that one.
I wouldnt mind knowing how much boost the bottom end would take.
If I wanted to build a superpowerful IDI I would build up a 6.9 because it has thicker cylinder walls. It could take more punishment.
I will probibly be doing my intercooler this weekend. Im going to pull the bumper and part of the front clip so I can at least get it mounted. I cant really pipe it up untill I get rid of that ATS intake box
And as far a your ATS airbox, you could just replace it with a cone filter setup and you would be good to go.
I was Considering head studs but with a intercooled setup, who needs over 15 psi anyways? I am getting 7-8 psi empty now, i will post results after i turn the fuel up. I have the gate at 13-14 psi so when it gets a load, it wont overboost. I dont see why I shouldnt get 230hp? Syco got 205 without a ic.
ok i have been out of the loop when did sysco break 200 rwhp
1993 F-250 SC 4X4 7.3/5spd/4:10 ATS WG turbo @ 12psi, 3" DP 4" straight exhaust, 5" stacks, Hypermax cowl induction, IP up 3 flats, typ4 BB injectors, GPR LED mod, Pyro/Boost guages-186whp 363wtq @ 10psi
1986 F-250 4X4 6.9/T19/3:55 Soup bowl mod, straight pipe
1967 Mustang 351/4spd
2006 Jeep Liberty 3.7/AT (Wifes ride)
hers his sig off obn
1993 turbo IDI on the dyno - YouTube
on
it took Heath a set a Moose Injectors + the hot Moose Turbo IP to find these numbers remember;
https://www.ford-trucks.com/forums/9...torque-rw.html
if you get the same with a banks + intercooler + stock BB codes + stock DB2831-5013/5028 N/A ip,that's rated to deliver up to 185hp,then you'll prove one thing;
efficiency trumps rolling coal. good luck!
on
no i don't think so.it's the the sticky thread on oil burners that's listed as "dyno with moose " etc. if ya want to ask him any questions.
this is why i say if you come close with your lower fuel setting ip,it will really look great for the efficiency of an intercooler,cus it took him large amounts of fuel to hit it.which is of course is not an issue on a play truck,or occasional driver even.but lets say i wanted to pick a truck that got 200hp at the wheels,driving a truck to make $ with.i wouldn't be picking the one "done via fuel" for 20k miles per year @ $4 per gallon.
#29
To me nos is better it makes sense I think heres my theroy.... on a gas you can control the point of ignition cause the spark sets it off at the same point each time. On a diesel though you cant with power adders altering the explosion and fuel makeup and propane and methanol are more volitile than diesel fuel so they can go off at any point of the compression stroke they are very moody and make big problems possibly. I am not saying my theory is right and i know lots of guys use propane and methanol but you see way more spraying nos and in way larger shots to the reason is it is more user and point of ignition friendly. Also lets look at this factor to what does propane do with your egt's they go up more methanol helps but only if you do water with it. Nos will net you more power while stopping that pyro when you induce it into the mix. I personally saw a 7.3 powerstroke with stage one injectors a garret 38r turbo and valvesprings got iirc 240thousand plus miles and its running powder metal connecting rods which the cardinal rule says dont exceed 400hp at max with i think he made like 350-420hp with that. Well a guy who was spraying on his truck took the hose stuck it up the intake right infront of the turbo ran the hose into the cab had bottle in passenger side of the truck mentioned. The truck on his last pull the guy turned on the bottle the numbers were 566hp 1006tq and that was with that crude setup he did in 5min im sold on nos. Just my theroy and 2 cents not poking anybodys buttons i hope
#30
My take on a Mustang dyno is that they sometimes do read lower on gas engines but read a bit higher in our diesels cus they properly load our engines as opposed to inertial dynos which have a set load. That is why I would think they read higher on our trucks. But ya go for it. I really wanna see what your truck does with the intercooler. It will show how much these engines really need them. When do you plan on dynoing it?
