rear diff oil change
Old 09-17-2011, 01:41 PM
renoduckman's Avatar
renoduckman
renoduckman is offline
I know this has been talked about before. But when do you guys like to change your rear diff oil? I dont see it in my owners manuel. I have a standard diff, not the limited slip. Joe
Old 09-17-2011, 02:07 PM
woodnthings's Avatar
woodnthings
woodnthings is offline
Usually around a 100k. I changed mine at 60k, but I use mine to tow mostly.
Old 09-17-2011, 02:18 PM
clintbonnie's Avatar
clintbonnie
clintbonnie is offline
According to my owners manual, maintenance guide, and I quote:
"Rear axles containing synthetic lubricant and light duty trucks equipped with Ford-design axles are lubricated for life. These lubricants are not to be checked or changed unless a leak is suspected or if axle assembly has been submerged in water.. Non-synthetic rear axle lubricants should be replaced every 3,000 miles.."
If you don't have a copy, go to:
https://www.fleet.ford.com/maintenan...ls/default.asp
Old 09-17-2011, 02:34 PM
RainStroked's Avatar
RainStroked
RainStroked is offline
I wouldn't follow what the owner's manual says in this case, I change mine every 40-50k or so.
Old 09-17-2011, 03:49 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
I first changed mine around 140k and am coming due again in a couple of thousand miles. For sure I will change again before 300k. It is about 10th or 12th place down on the "PSD List"
Synthetic gear oil is amazing stuff...
Bigdflyer
2017+ Super Duty
36
09-28-2018 10:58 AM
TheACN
1997-2006 Expedition & Navigator
01-22-2013 10:09 PM
BeBo03
04-26-2008 10:43 AM
zomowiec
09-23-2006 06:26 PM
jake98
1999 to 2016 Super Duty
01-31-2005 09:50 PM
Quick Reply: rear diff oil change
