Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- Why is My Power Window Not Working?
Guide to diagnose trouble and recommended solutions
POWER WINDOWS & RADIO electrical problem
Open and kind of firmly shut the drivers side door next time it happens and see if they start to work.
I had this same problem twice while camping this summer, once I just jiggled the ignition a tiny bit and everything started working again. The second time I started playing with the ignition but accidentally shut the truck off, when I restarted the truck everything worked.
That was the only times it ever done it to me until just a couple days ago when I was cleaning the X. I thought maybe bad wire in one of the doors because I had them all open. What fixed it this time for me was wiggling/pulling and reinstalling the "delayed accessory" relay. But at the same time I shut the drivers side door (for the second time). So I am hoping it is something with the relay and not me shutting the door shaking a wire somewhere in the truck.
You're right about it staying inoperable, as long as the windows are up when it happens,
I had a simular problem in the past with the battery saver relay malfunctioning. It would never do it while at the dealer (while under warranty)so they could witness it, and they would never take my word for the symptoms. Last year I had to have the drivers door power lock changed and told them to replace the battery saver relay which is part of the instrument cluster and thet solved the problem I had been dealing with for 3 years ( no interior lights when using the remote door lock)
Anyway I think if I can keep this post at the top for a while someone who has had this problem fixed will see this and respond.
David
David
Please see my answer to this problem at this thread:
https://www.ford-trucks.com/forums/1...cal-issue.html
#29
Power windows and radio issue
I have a 2003 Excursion with a 6.8L V10 and I am experiencing the same exact problems as you all are. The power to the radio and power windows will go out and then come back on sometimes a few minutes later, sometimes a half hour later. There isn't anything that I do to make the power go out and there isn't anything I do to make the power come back on. I came on here to hopefully find a fix for the problem. Has anybody fixed their problem yet? I called my mechanic and he said that he can't fix the problem if there is power to the radio and the windows. The problem is that even if the power is out to the windows and the radio when I bring it to the garage the power might come back on without warning and the mechanic will think that he has fixed the problem when he really hasn't. Any luck anybody?
#30
No fix yet. It's been doing it a lot more recently, like every time I drive it. Last weekend I removed the instrument cluster & checked all connections which were good and reassembled everything. Still have the same symptoms. Next I'll check the CENTRAL JUNCTION BOX as per HOUSEDADS link, just waiting to find out if the CJB is what's also known as the fuse box or if something totally different then where is it (CJB) located.
I have even considered replacing the intrument cluster again just to see if thats where the problem's coming from since hitting the dash above it will usually bring the power back on, just a little too pricey unless I can be more sure that's it.
