2002 EX Overland build - THE KRAKEN
Hello fellow EX folks. I’m building out a 2002 V10 EX
I’m in progress and this is ultimately not just a bad *** rig but also a proof of concept for future builds.
you can follow the build @cooperskraken on IG and FB
Im taking out the third row seats as well as the smaller passenger side second row fold up seat. I’ll also be removing the rear side panels and replacing them with custom welded aluminum boxes for storage.
The rear bed of the EX will have a custom built storage utility bed slide that will house all the water, electrical, cooktop, sink and battery chargers.
I might be interested in adding an inverter as well as an on-demand hot water system. Still thinking about that.
if you’re interested in this build please follow along, ask questions and I’ll make sure to keep this thread going.
I am not a PRO, just a dude that likes to build and learn new skills.
The following 6 users liked this post by Cardboardcoop:
Will the fresh water tank be stationary or does it live on the slide out tray? Seems to me that stationary would be better as it would get a lot of weight off the slides at all times, both in and out. You would have to reroute the water outlet and fill ports to a fixed position on the side.
Since you already have a heat source onboard (under the hood) maybe a fresh water vs coolant heat exchanger could be your hot water supply with less equipment and electrical draw. Would obviously need to run the engine for a short bit to heat up for a shower. Will you have a propane tank onboard for cooking? Another option might be a small RV hot water heater, our TT has a dual heat (110 A/C & propane) that easily supports back to back showers for my wife and I with the water running for the entire shower, not on/off "Navy" showers. Not sure how small these RV HWHs come, maybe the ones in Class B van campers are small enough for your application.
What size tires are you running (nice looking EX!) and what gear ratio does it have? For rough off-road going, rock crawling, heavily loaded or towing deeper gears are really something to consider, my swap to deeper gears is the single best mod that I've done for my EX. The V-10 likes the effective 4.30-4.56 range for the best performance when working hard.
For what you are doing I think your aluminum welds look fine, what process are you using? I need to invest in a better TIG to allow me to start glueing aluminum together.
The following users liked this post:
I did just order an on demand hot water heater for my Van conversion. Was thinking that might be a nice addition to the Kraken. That would live in the spare tire extra space. It’s a bit unnecessary, you could always heat water on the stove for dishes and bird baths.
I’m interested in the re gearing. Seems like that would help a lot in all kinds of situations.
I just learned to weld. I’m using an aluminum MIG as I don’t think I have the patience for TIG. I also wanted a system that could easily switch from aluminum to steel. Depending on what I’m building. I have plans for a small ladder and utility mounts along the side over the larger rear panel windows.
thanks for the interest!
Cool build idea. I’m planning an overland inspired style build for my Ex ( by overland inspired think like how mall crawler Jeeps are rock crawler inspired type thing)
Could you keep this thread updated periodically for those of us that don’t do Facebook or IG please?
Have you explored opening up the interior side of the rear barn doors? They are hollow and offer a couple more small but useful storage bays, a few owners here have done them over the years and there were a few Icelandic glacier tour rigs that had nice little bars fitted inside the rear lower doors.
And here's a cool how-to on a interior release for the rear hatch.
https://www.ford-trucks.com/forums/1...-tutorial.html
Nice! Following along as someday I wouldn’t mind turning mine into more of an overland type rig. Mostly simple thoughts on my end though. Just enough for a bed and couple days “camping” in the wilderness to get away from the RV. I would strongly consider a propane on demand hot water heater for sure. There’s all types/sizes, so you could go just about ant direction with that. Fun stuff!
