Starting Troubles
Old Apr 6, 2003 | 12:31 AM
f1drivr's Avatar
f1drivr
Starting Troubles
I have a EFI in a 1951 Ford truck. It's been sitting for about 2 years.I tried to start it the other day ,It would not start until I primed the intake with fuel. After that it would run fine.I tried to start it the next day,same thing happened. I just replaced the fuel pump. Thanks
Old Apr 8, 2003 | 03:19 PM
Ford_Six's Avatar
Ford_Six
Starting Troubles
Possibly a bad fuel pressure regulator, allowing fuel pressure to bleed off. Also, I would check the fuel pump relay.
