Sponsored by: Real Truck
Lost gauge cluster
Old Sep 16, 2011 | 09:52 PM
jc8825's Avatar
jc8825
Lost gauge cluster
I was driving home from work this evening and it has been raining for a few hours, so there is quite a bit of water on the road combined with extreme drought conditions, the roads were slick, so I was using 4WD and I switched my O/D off. Drove to the house, shifted into Park, reached up and pushed the O/D button and the cluster died. Truck still runs, just no cluster. I assume it blew fuse 35, but I will check it out when it stops raining tomorrow. Thoughts?
Old Sep 16, 2011 | 10:22 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Fuse. Thats my guess.
Old Sep 16, 2011 | 10:24 PM
jc8825's Avatar
jc8825
Maybe that fuse was weak or something? Can fuses get weak? I just don't understand what would cause it to do that. I fixed the chaffed O/D wire in the column a while back. I have never had this happen before. Hopefully it will be an isolated incident.
Old Sep 16, 2011 | 10:28 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Maybe some water got in somewhere. I decided to hose down my F150s engine one time. Shorted out ALLLL kinds of stuff. Gauges were partially lit, honking flashed the high beams (yes, it was as comical as it sounds haha). Thankfully nothing vital was lost, and over time it fixed itself.
Later that night the truck was totaled due to an unrelated matter, so I never got to resolve it completely...
Old Sep 16, 2011 | 10:58 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Have you seen this?
https://www.ford-trucks.com/forums/1...tch-short.html
Old Sep 16, 2011 | 11:11 PM
jc8825's Avatar
jc8825
Well, I have no leaks. I checked that a while back. I also fixed my chaffed wire before it wore through, and everything has been working fine.
Old Sep 17, 2011 | 12:58 PM
jc8825's Avatar
jc8825
Okay, I investigated today and it was fuse #45 that was blown. The manual lists it as 'Ignition switch Start/Run feed'. I replaced the fuse with a new 10A, and the cluster came to life. As soon as I switched the O/D off, the fuse blew again. I tried a 15A and then repeated the above, and it didn't blow. Then I removed the 15A and put in a new 10A, and it didn't blow. I left the 10A in there and switched the O/D on and off many times, and no fuse blown. It seems to be fixed.
Old Sep 17, 2011 | 08:38 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
"fixed" is a loose word apparently lol
Old Sep 17, 2011 | 09:07 PM
jc8825's Avatar
jc8825
I like things that fix themselves and don't cost me any money!
73stang
Oct 21, 2016 09:21 AM
95broncoguy
1978 - 1996 Big Bronco
Mar 30, 2013 04:02 PM
GreenMachine
Electrical Systems/Wiring
Jul 29, 2007 12:34 AM
Big Red F250 SD
Mar 31, 2006 10:11 AM
