Replacing A/C o rings
Old Sep 16, 2011 | 06:38 PM
tekrsq's Avatar
tekrsq
My camper's A/C (87 E350) is leaking, and I assume it is due to bad o rings in the plumbing. One of my winter projects is to replace the o rings, but I honestly don't know how. I've searched for a step by step, but can't find one. Can anyone give me a quick down and dirty ?
Forgot to mention, it was converted to 134a several years ago, but apparently they didn't change the o rings.
Old Sep 22, 2011 | 02:55 PM
hhott71's Avatar
hhott71
You need these
The spring lock fitting tools They disconnect the snap together fittings.
Your local autoparts store sell them.
Fitting with Regular Hex nut fittings, use wrenches....
You'll see the orings, remove and replace. Lubricate them before reassembly.
evac and charge to 80% of the R12 charge weight.
Old Nov 7, 2011 | 10:23 AM
dustmote's Avatar
dustmote
I'd recommend that you get the springlock coupling disconnect tools from Harbor Freight..... I think I paid about six dollars for mine, and they work for disconnecting the spring lock couplings on fuel lines as well.....
Also, does anyone have the spec on how much r12 is supposed to be charged into the system by weight??
Old Nov 7, 2011 | 05:07 PM
tekrsq's Avatar
tekrsq
Thanks guys !!!!
I want to fix this in the spring. I think there are only 2 of those spring lock connections (that's all I can see). The biggest problem I got is being able to vacuum out the system before recharging it. I might buy one of those cheap systems to do it, if I can't find somebody that already has one. The cheapest price I got for a shop to fix it is $500.
Black Ford XLT
Feb 26, 2018 10:41 PM
MrRogers
Aug 1, 2012 02:30 PM
woodallap
Sep 28, 2006 10:37 PM
michael71
Jul 16, 2006 02:15 PM
MufassaMaxx
Jun 4, 2002 08:39 PM
