I have been going through all my bits to install the turbo that has been sitting on a shelf for almost two years now and I realized that the wire harness for the pyro was damaged. It looks like it was pinched in something and is almost cut in two. Its the shorter section that is attached to the probe. Can this be repaired without altering its ability to measure correctly? What is the best way to repair if it can be?
It can be fixed. You can use a crimp connector to fix it. Cut the conn ector in half. Stick the wires into it so that they are touching each other and crimp.
PS: Be sure to seal it with liquid electric tape to prevent corrosion.
I wouldn't recommend using a standard crimp connector (unless plastic only), as it will alter the reading because of a dissimilar metal being introduced.
Mine got pinched & damaged before I even put it in the truck (moving), the damage was so close to the plug, I just cut the wire and reattached it to the plug like stock, losing less than 1/2 inch of wire. It's worked fine, and I don't push my truck (even when loaded and uphill) to get anywhere near 1000 degrees.
Thanks for the info. I think I got lucky, the steel braided shielding was cut in half but when I pulled the two halves apart the two inner wires were still intact. The coating is worn off but the wires aren't broken. An avionics tech at work is going to help me with a repair. That will save me $50 for a new harness.
If the connections are close enough to be at the same temperature as a crimp connector would be, the error incurred would be nil. Each junction acts as a thermocouple. This means the the alloy to copper would create a thermocouple junction,then the copper to alloy would create another equal junction but opposite to the first. They would nullify each other as long as there was no temperature difference between them. If you're still paranoid about it, if you made sure that the alloy conductors were touching when you crimped it, you would guarantee no error introduced.
