torque setting for drag link
Old Sep 15, 2011 | 08:54 PM
49m47's Avatar
49m47
I finished putting on my new King pins and bushing. While I had it apart I went ahead and changed out the tie rod ends. While I'm in there I may as well take the drag link apart, clean and inspect. It looks fine, so now its time to go back together. So I'm looking for the torque setting or rule of thumb as to how tight to tighten them.
As usual I'm look for advice.
Thanks
Old Sep 15, 2011 | 09:19 PM
dongc1's Avatar
dongc1
There is no torque setting.
The procedure is to tighten the plug as tight as you can to sure the spring is fully compressed. back off the plug to the first cotter key hole and install the cotter key. Be sure to get the springs in correctly, they are different from one end to the other.
Old Sep 16, 2011 | 09:37 PM
49m47's Avatar
49m47
That's kind of where I was. I just wanted to hear if from some one else to. I couldn't find anything different with the springs. They were the same on both ends. There was no tapper, ID and OD are the same and the spring wire diameter was the same.
Thanks for the help
Old Sep 16, 2011 | 10:20 PM
dongc1's Avatar
dongc1
Thanks for the help
The springs are the same, but they install differently from one end to the other end. See the factory manual.
Horace18
Nov 30, 2017 04:01 PM
Michael Levy
13
Apr 11, 2017 06:11 AM
acf6
May 2, 2013 09:23 AM
Unrealo4
Mar 9, 2011 04:57 AM
I_Love_Cheese
Jun 7, 2007 06:42 PM
