Front end torque specs
Old Mar 7, 2011 | 04:32 PM
Unrealo4's Avatar
Unrealo4
Ok I searched all over for torque specs. And couldn't find much. I need torque specs for the following.
Front axle u-bolts
Front leaf spring pack pin
Track bar both ends
Sway bar
Tie rod ends (all)
I have some work to do and don't want to go in blind. If anyone has a link to somthing were I can look all this up that would be great. Truck is the one in the sig.
Thanks,
Old Mar 7, 2011 | 07:00 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Hey, you might get some of those torques here:
http://www.revtek.com/docs/pn6126.pdf
It's a suspension installation instructions, but hey, you have to get them from some where!
Hope it helps.
Old Mar 8, 2011 | 12:55 PM
amdriven2liv
Here are some more.
Ford Powerstroke Diesel Forum
Old Mar 8, 2011 | 05:54 PM
Unrealo4's Avatar
Unrealo4
Thanks man sorry wanted to get back to this but I just went on a 12hr plowing binge. The 2nd link just sends me to the login screen.
Old Mar 8, 2011 | 07:23 PM
amdriven2liv
Here I copied and pasted it.
Tie Rod End —Inner, castellated nut....................90 Nm
Tie Rod End —Inner, Sleeve Clamp Bolts................55 Nm
Drag link to pitman arm nut.................148 ft-lb
Inner & outer tie-rod end nuts................85 ft-lb
Track bar bracket to frame.....................129 ft-lb
Track bar to track bar bracket bolt............406 ft-lb
Track bar to axle nut................................... 185 ft-lb
Radius arm to axle bolts, and bracket nut.........222 ft-lb
Pinion bearing preload..................................10-20 in-lb
Pinion nut............................................... ..220-280 ft-lb
Ring gear bolts............................................1 20-140 ft-lb
Bearing cap bolts.........................................120-135 ft-lb
Steel Diff cover bolts....................................30-40 ft-lb
Cast aluminum diff cover bolts......................... 24 ft-lb
Wheel lug nuts..........................................120-165 ft-lb
Diff filler plug.............................................1 8 ft-lb
Oil filter cap............................................... ...14 ft-lbs
Engine cover bolts............................................. 15 ft-lb
Fuel return hose.............................................. .....19 ft-lb
Fuel supply hose.............................................. .....37 ft-lb
Injector hold downs....................................24 - 26ft-lb
EGR cooler clamp.......................................53 in/lb
Turbo mounting bolts.................................... 18ft-lb
Turbo pedestal bolts....................................23 ft-lb
Turbo inlet clamp.........................................9 ft-lb
Exhaust manifold.......................................... ...45 ft-lb
Idler pulley mounting bolt..................................... 41 ft-lb
Brakes, disc, front brake caliper pin bolts (2)......................42 ft-lb
Brakes, disc, rear brake caliper pin bolts (2)......................27 ft-lb
Brakes, front disc brake caliper anchor plate bolts (2)...........166 ft-lb
Brakes, rear disc brake caliper anchor plate bolts (2)......128 ft-lb
Brakes, Caliper Bleeder Screw................................13-18 ft-lb
Crossmember Bolts............................................. ....70 Nm
Driveshaft to transfer case bolts..................................111 Nm
Flex Plate Inspection Cover......................................20 Nm
Master Cylinder Outlet Tube Fittings.........................19 ft-lb
Shock Absorber (front)......................................76 ft-lb
Shock Absorber (rear).....................................46 ft-lb
Stabilizer Bar Link Bolts.........................................85 ft-lb
Starter Mounting Bolts......................................22-28 Nm
Thermostat Housing.......................................20-30 Nm
Torque Converter Drain Plug .............................12 Nm
torque converter retaining nuts............................35 Nm
Transfer Case Bolts...........................................31 Nm
Transfer Case, fill/drain plugs...............................27 Nm
Transmission Filler tube bolt..........................10-13 Nm
transmission fluid cooler tubes to cooler bypass valve............27 Nm
Transmission mount-to-cross member nuts...........94 Nm
Transmission, Auto, Drain Plug....................25 Nm
Transmission, Auto, Pan Bolts (20)............11 ft-lb
transmission-to-engine bolts................61 Nm
Water Pump Bolts...........................18 ft-lb
Water Pump Pulley bolts (4)...............18 ft-lb
Wheel Bearing/Hub Assembly Nuts (4).........135 ft-lb
Power steering pressure hose.......................24 ft-lb
Power steering pump mounting nuts......................41 ft-lb
Old Mar 9, 2011 | 04:57 AM
Unrealo4's Avatar
Unrealo4
Wow that's a good list. I think that should go somewhere in the tech folder. Reps on the way!
rsjimenez
Nov 2, 2015 09:35 AM
jawdoc
Sep 10, 2015 09:39 AM
timf150
Apr 2, 2012 03:34 PM
jettester
Large Truck
Jul 25, 2011 08:47 AM
fxstdi
Jul 10, 2011 10:14 AM
