need help
Old Sep 14, 2011 | 07:16 PM
cbarnfield's Avatar
cbarnfield
need help
i have a 94 f-350 7.3l diesel turbo and just changed fuel water filter, primed filter reinstaled. cranked runs fine, but went to test drive when i excelerate motor boggs and big cloud of smoke. what did i do wrong ??
Old Sep 14, 2011 | 07:29 PM
IDIDieselJohn's Avatar
IDIDieselJohn
What color is the smoke?
Old Sep 14, 2011 | 07:55 PM
cbarnfield's Avatar
cbarnfield
a little bit of white but alot of black
Old Sep 14, 2011 | 09:24 PM
IDIDieselJohn
White is unburnt fuel caused by bad timing.
Black is unburnt fuel caused by to much fuel to air mixture. Like a gasser running rich.
Has the fuel been turned up any on the injector pump?
Old Sep 14, 2011 | 10:48 PM
Aune163rd's Avatar
Aune163rd
x2 on the injector pump, black smoke can also mean that your air filter is clogged or something...
Old Sep 15, 2011 | 12:01 AM
cbarnfield's Avatar
cbarnfield
I had brought my truck to a local mechanic and i think thats what he did to compensate for the dirty filter. when i removed the filter it was black sludge. i dont know where or how to re-adjust ?
Thanks!! In-advance
Old Sep 15, 2011 | 05:42 PM
cbarnfield's Avatar
cbarnfield
An update on my 1994 f-350 7.3l diesel turbo, with the fuel adjustment proplem. After reading the post left on my comments, it was mentioned to check the air intake and I had just replaced the air filter the day before. On this year model it take the flat square filter with the foam filter as a separte piece.I think you can see where this is going, yea I put the foam piece on top and it sucked it into my turbo causing a blockage to say the least.So I simply removed it and it runs like new.
bubba_3711
Aug 26, 2014 06:03 AM
akamacgyver
Apr 4, 2011 12:04 PM
oubegood
Jul 2, 2010 10:49 AM
ryans10pointer
Sep 8, 2006 08:48 PM
Vinford
16
Apr 5, 2005 10:28 PM
