Mileage
Old Sep 14, 2011 | 10:56 AM
DanS12's Avatar
DanS12
Mileage
What are some of the best things to do to make your diesel dollars go further?
I get around 15-16 MPG, completely stock truck with 288,000 miles. No engine work ever done, other than basic repairs.
Old Sep 14, 2011 | 10:58 AM
Copedawg's Avatar
Copedawg
Dan, try to drive easy and slow. I think that is the biggest MPG killer. I get terrible milage b/c I drive like a maniac.
You should mod the DP and air intake.
That will help.
Old Sep 14, 2011 | 11:42 AM
tshrager's Avatar
tshrager
Synthetics in everything. Make sure your rear brakes aren't dragging. Correct tire pressure. Check map sensor/tube and what Ian said
Old Sep 14, 2011 | 12:45 PM
BuckHammer's Avatar
BuckHammer
Yeah. I agree with what Ian said. Driving habits make the biggest difference. A good thing to do is the RiffRaff 6637 air filter kit and a 3" exhaust downpipe.
Old Sep 15, 2011 | 12:23 AM
96oldstroker's Avatar
96oldstroker
I've been struggling with poor mileage too. I'm hoping that cleaning the little screen in the fuel bowl will help, it sure sounds and runs different. I haven't had a chance to drive it very far yet. I'll let you know after this weekend. I just put a dominator 66 turbo(my fins were torn and jagged on the original) and 3"dp on before driving from phoenix to chicago and back thinking that it would be better, but it was only barely better. best was 12mpg, worst was 8.5mpg. with a cabover and trailer(5x14) with 6 dirtbikes. it's a stock motor other than those 2 mods and a k&n and superchip. it got 18mpg empty when I got it in '98.
Old Sep 15, 2011 | 12:30 AM
deadsenator's Avatar
deadsenator
Upgrade intake/exhaust as mentioned.
No boost or exhaust leaks.
No fuel leaks.
Lubricate your fuel.
Don't put a lift kit on your truck.
Don't put big tires on your truck.
Put in higher gear ratios.
Put in a manual transmission.
Air up the tires to max pressure. Mine are at 65psi. Harsher ride, but she rolls easier.
Keep RPM's under 2000 whenever possible.
Anticipate traffic. No hurry up then brake type driving. Let none of the effort be wasted.
The "perfect" econo 7.3 would be a standard cab, 2x4, SRW, no lift, no large tires, manual transmission, and 3.55 gears. This truck, driven with an egg under the go-pedal should get low 20's.
I get 16 around town (19+ HWY), which I consider pretty good given that I have a big truck with the basic power mods. I drive the car more around town though.
There is a guy on one of the other forums that can get 28MPG with his (modded) SD. No lie.
Old Sep 15, 2011 | 07:57 PM
F350-6's Avatar
F350-6
If you want good fuel economy, you need to adjust the nut behind the steering wheel.
As mentioned, driving habits will play the biggest factor. Maintenance and fixing any leaks will help also. Beyond that, it becomes very hard to see a savings in fuel economy by spending money on upgrades unless you put a lot of miles on the vehicle.
Old Oct 11, 2011 | 08:58 AM
96oldstroker
just wanted to report-I have a 96 cc, longbed, 4" lift, 33s, a superchip, dominator66 turbo, and a k&n. I just cleaned the screen in the fuel bowl, and put a bb in the fpr and finally drove my truck w/o the camper and got 22.6 miles per gallon. I went 52 miles at about 68 mph for most of it and about 4 miles of stop and go. I'm thrilled, been struggling with poor mileage for years.
Old Oct 11, 2011 | 09:42 AM
bearhugger's Avatar
bearhugger
Best way to check milage is over several tanks full.I checked mine over 3300 miles and got 19.4 mpg driving 70 + mph.95 f350 cc std with 3:55 gears.
Old Oct 11, 2011 | 10:26 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Have you corrected the speedo for the size of your tires? 22.6 MPG are wonderful.
BTW ditch that K&N.
Old Oct 11, 2011 | 01:17 PM
96oldstroker
I have not. How do you do that? I'm about to get new tires and wheels. I have 16.5s and they've been telling me for years that they're(tires) gettting harder to get. So far they've been in stock or in town. And, I know about the K&N, i need to order the 6637 from riffraff.
Old Oct 11, 2011 | 05:55 PM
96oldstroker
I feel like a ******* now, I just went 60 miles, drove really light to see how much better mileage I could get, remeasured it and got 11.7mpg. (5.1 gallons) so scratch the 22.6, it must not have been all the way full. I'll have to check it on a longer trip where I get gas several times.
Old Oct 11, 2011 | 06:19 PM
427 fordman's Avatar
427 fordman
I just checked mine today. 123.1 mile round trip at 65mph, made 17.7. 10 miles of town driving, rest highway. Pushing a pretty good headwind by the time I came home. Filled up till it clicked at the same station, same pump, before I left and after I got back. In 140 tune. Not great but not bad, I did have to get after it a few times to pass some vehicles.
Old Oct 11, 2011 | 07:31 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Read this:
https://www.ford-trucks.com/forums/7...libration.html
Old Oct 11, 2011 | 07:37 PM
BIGRED 7.3L's Avatar
BIGRED 7.3L
I have read dozens of MPG threads and there are so many factors that affect truck to truck, tank to tank. Tire size, speedo/odometer error, how full the tank was and how full you think you got it on the refill, gearing, driving habbits. I think for us uncorrected tire size/speedo and whether the tank is as full are two big factors when trying to compare truck to truck that are otherwise comparable. Claims of a CC 4x4 with 33s or even 35s getting upward of the 20s just seems like a stretch to me. I keep trying though. 17.5 is the best I can do on my stock truck with 33s.
