Motorcraft Mercon SP
Old Sep 14, 2011 | 09:08 AM
Special Ed's Avatar
Special Ed
Just purchased 2 cases from my local O'Rieleys. As I was adding the new fluid on a drain & fill I got to reading the label. "Do not use for applications where Mercon LV fluids are recommended." From all my reading I was under the impression Mercon LV is the recommended fluid now? Why does it say this if the two are suppose to be compatible? I will stick with SP until it is unavailable any longer. Also as I was pouring, it smelled like burnt trans fluid to me. Anyone else ever notice that?
Old Sep 14, 2011 | 10:33 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
SP really smells BAD!
Old Sep 14, 2011 | 12:33 PM
bpounds's Avatar
bpounds
Yeah, SP stinks bad. I wouldn't call it a burnt smell, so I hope that isn't anything important.
As for the LV note, it simply means that LV is backward compatible, but SP is not forward compatible. It is fine to use SP in your truck because that is the OEM specification.
I'm with you, and wish they had not discontinued the SP product. We have to just trust Ford that LV is every bit as good as SP, and I just cannot muster much trust in FMC decisions. I think they value their bottom line more than they value mine.
Old Sep 14, 2011 | 01:18 PM
Special Ed's Avatar
Special Ed
LOL, oh I agree with u 100% on that. Thanks for clearing that SP - LV thing up. Would it make sense to stock up on the SP? My local O'Reileys claims they have an unlimited supply of it from its supplier.
Old Sep 14, 2011 | 02:40 PM
bpounds's Avatar
bpounds
Personal choice, I guess. I don't stock up on fluids or filters or anything like that. It's just not the way I roll. Sooner or later I'll have to use LV, so let it be.
Old Sep 15, 2011 | 07:46 AM
Special Ed's Avatar
Special Ed
Sounds good!
Old Sep 16, 2011 | 09:33 PM
BobsF350's Avatar
BobsF350
Ive been using Valvoline Maxlife atf
Old Sep 17, 2011 | 09:25 AM
96_F250_Deezal's Avatar
96_F250_Deezal
Special Ed... how much, per quart, did you pay for the SP fluid. I can get SP through my local Motorcraft supplier for $5 a quart.
Old Sep 17, 2011 | 12:54 PM
69cj's Avatar
69cj
At our dealer LV is a buck a qt. cheaper tha sp.
Old Sep 17, 2011 | 01:08 PM
Special Ed's Avatar
Special Ed
$4.69 a quart
Lattitude Adjuster
Oct 10, 2014 07:44 PM
BAD RONALD
Jun 10, 2013 09:48 PM
1978Crew
Escape & Escape Hybrid
20
Jan 2, 2008 07:25 PM
exiled
Jul 14, 2007 07:25 AM
miichael
Mar 10, 2006 04:49 AM
