I am building a fuel injected 393w stroker motor. I have the motor completed now questioning if I should go with the 90mm or 75mm upper intake from TFS. Which will answer the question for throttle body size. Also thinking about going either 36 or 42lb injectors. Below are my numbers. I am looking for a street/strip engine.
The TFS intakes are designed for these larger throttlebodies so you're OK there, but they often require a different style throttle cable like the one found on the Lightning.
Also get a matching EGR plate. Make sure the TB opening is no bigger than the manifold opening, or it will have little additional effect due to air flow disruptions at the interface.
