View Poll Results: solve the problem of super duty truck
resolving injection PROBEM
0%
solve problems on
0%
Voters: 0. You may not vote on this poll
Super Duty 450.
Super Duty 450.
Technical data Engine: Diesel Motor, model A325, 6.0 liter, emission and control ECM EGR CAC TC DL OC.
failures: Starter turns, but not light, check the following: oil pressure reaches the distributor of the injectors, how many pounds of pressure should have?
passing the ignition swich sound reaches the injectors and a voltage of 47 volts, a voltage also comes intermittently.
When the crankshaft sensor comes a voltage of 1.5 V.
Dash lights passing the ignition swich turn all the services, oil pressure, heating coil, etc..
That model would be the right scanner for this model engine?
What would be the procedimeinto to remove the injectors and proceed to try?
The turbo to manually turn it feels harder than normal.
When step swinche ignition to turn the starter's signal was a flashing signal injector, then cut by rotating the motor.
Vehicle Features: Super Duty 450.
kevmiester
Apr 15, 2017 12:54 PM
med-care-guy
Jul 18, 2012 10:29 AM
