front ujoint
Old Sep 11, 2011 | 12:15 PM
gumper 123's Avatar
gumper 123
front ujoint
hey guys got a question put all four ball joint in last weekend drove it last night for first time all was well. my wife moved truck today heard it clicking front right ujoint looks good no play in it but yoke is hitting nut on lower balljoint bearing is good in spindale upper ball joint could be pressed about 1/16 deeper but would not keep it from hitting any ideas?
Old Sep 11, 2011 | 01:22 PM
Aune163rd's Avatar
Aune163rd
Is this the 94 or the 92? It might be the tie rods possibly??? If it was from the right side, then someting aint right cause the driveshaft either went to the drivers side or the center on the D60(dont quote me on that) so you might want to check your ball joints.
Old Sep 11, 2011 | 01:30 PM
gumper 123's Avatar
gumper 123
Its the 94
Old Sep 11, 2011 | 02:42 PM
gumper 123's Avatar
gumper 123
went out took it all back apart thought maybe lower ball joint was not up in knuckle all the way i think it was now it goes up to the fatest part of tapper is flush wit bottom of knuckle the yokes at u joint are still rubbing top of threads of bottom balljoint. my chilltons book dont have s??? for info. the right side is the long axle side what holds the shaft center is somthing missing at end of axle housing
Old Sep 11, 2011 | 04:51 PM
kenpobuck's Avatar
kenpobuck
Is the new ball-joint the same as the old one? I mean is the base the same thickness? I know it is a different year and much newer, but my buddy did his on his 98 250 4x4 and the driverside u-joint was hitting in the same place (on the bolt head). Luckly he had not junked the old ones yet and comparing them we found the new aftermaket was thicker and allowing the yoke to hit it. Just an idea.
Old Sep 11, 2011 | 06:36 PM
gumper 123's Avatar
gumper 123
the dam thing was pulled out of socket just put a new one in good clearence now.
jakeharp
Jun 7, 2018 05:34 PM
ARK-F150
1978 - 1996 Big Bronco
Dec 20, 2015 07:15 PM
jtharvey
40
Jul 30, 2008 06:38 AM
68-F250-4x4
Apr 7, 2008 07:57 PM
Inepsa
22
Mar 7, 2008 03:15 PM
