Broken 4x4 floor shifter assembly
Old Sep 10, 2011 | 07:21 PM
jostrout's Avatar
jostrout
I broke the cast shifter assembly for my 97 F-350. Anyone know a easy way to dissasemble the shifter linkage to remaove assembly for replacement?
Old Sep 10, 2011 | 08:44 PM
nothingnew's Avatar
nothingnew
The way I remove em is take the 2 bolts out of the plate that the pivot bolts into, work on it in a vice, most likely it broke due to the pivot bolt beeing siezed , next I use heat to free the shifter from the bolt. you will smoke the bushing doing this but a new one is only a few bucks. Dont break the pivot bolt dont think you can get a new one, or its big money. Think a new shifter is about 200 bucks. good luck hope this helps
Old Sep 11, 2011 | 07:28 PM
jostrout's Avatar
jostrout
Thanks. I popped the linkage out today and removed shifter assembly from floor and then removed bracket. I put it in the vice and removed pivot bolt. It was pretty rusted and had to be worked with oil to get out. Thanks for the info.
npavao86
Nov 20, 2016 08:23 PM
killacal
1997 - 2003 F150
Jan 4, 2016 05:40 PM
torquemeister
Aug 27, 2014 09:16 AM
torquemeister
Aug 26, 2014 10:03 PM
RealLow4.2
3.8 & 4.2L V6
Jan 1, 2005 08:34 PM
