Front disc
Old Sep 9, 2011 | 10:27 PM
lil neet's Avatar
lil neet
Front disc
Was front disc a option in 69 on f100 ?Ours has front disc that look original .If it was it a rare option ?
Old Sep 9, 2011 | 11:26 PM
HIO Silver's Avatar
HIO Silver
According to the 1969 Ford Trucks sales brochure, discs weren't an option for the F100. 69brochure_p12
More evidence from Fordification: Installing Disc Brakes on Your 2WD Pickup - Pt. 1 - FORDification.com
Although Ford started installing disc brakes on the F-250 in 1968, they were not factory-installed on the F-100 until 1973...the first year they were standard equipment on all F-100 through F-350 trucks....
Maybe a way to gain some more insight is to look at casting number on your I-beams and decode them on this page: Steering/Suspension Component Variations - FORDification.com
If it starts with a "C" then your rig has at least period correct I-beams and the brakes might be from a newer rig. If it starts with a "D" then that's a 70s era part and not original to your 69 and someone likely swapped in the I-beams and discs.
'hope that helps.
Old Sep 10, 2011 | 12:08 AM
lil neet's Avatar
lil neet
Thanks for info .My truck has drop lowering beams on front so it seems most likely swapped out discs .
Old Sep 10, 2011 | 12:49 AM
Ford_Six's Avatar
Ford_Six
If they are Ford calipers, then most likely 73-79 stuff fits. Some kits use GM or GM style calipers, though. If it has wedge pins holding the calipers, it's Ford. If it has two allen head slide pins, it's GM style.
racer2012
Dec 9, 2021 11:32 PM
65 Ford Truck Man
Aug 14, 2012 11:05 PM
sweets64f100
Nov 26, 2004 10:19 PM
racinherby
Apr 27, 2004 08:59 PM
avery
Jul 7, 2003 05:23 AM
