i have a 86 f-150 4x4 3oo six,primarily a woods truck,i put a non electronic carb and a points type distributor.set points to .027,plugs(autolite 45)to .034,verified like twenty times #1 TDC,compression 160 across the board,tries to start then acts like it floods and popback thru the carb. #1,2,5,dry#3,4,6 WET tried switching wires 180 just for sh-ts and grinns to no avail. any ideas ? HUNTING SEASON WILL BE HERE SOON,
Reason: MISS WROTE DRY WHEN SHOULD HAVE WROTE WET
It has been a very long time since I fooled with points, but I thought the gap was more like .016"? Is the condensor good? Is the voltage to the coil correct? The 1986 truck had a resistor wire supplying voltage to the coil and I don't remember if the pre-electronic systems did.
i bought the oem replacement coil i noticed it said for external resistor,but i got 4 ohms instead of the lower 1.0 to 1.6 so i hooked the coil to direct battery while cranking with the same result,a friend suggested possable collapsed lifters,but that seems odd since the truck ran before i did this,and the reason i changed it was because the electrical parts of the old carb were bad and this seemed more cost effective at the time
Turn the dist a little bit and try it again. If it gets worse, try turning it a little bit the other way. If it gets better keep turning it in the good direction till it half runs and you can get a timing light on it.
yea got a reman distributor,reman carb and new coil,pretty basic swap i thought,well i appreciate the suggestions i am waiting for it to quit raining and i will go over everything one more time,i am gonna pull all 6 plugs and crank it with them connected and watch the spark ,and i will check the condensordoes anyone know how to checkit or what readings i should have?
These engines have two timing marks, one on the front of the timing cover, and one on the right side of the engine. Use the mark on the right side of the engine.
I've made the mistake of using the wrong mark before, and it just won't work.
BTW, right side of the engine means right while sitting in the truck.
Good luck.
Good luck.
Very good point!
Some trucks from the factory had "TWO" timing marks on the damper, so it will not matter which timing mark you use. Some dampers (especially aftermarket replacements) only have "ONE".
The timing marks on the right are the most universally accepted.
If your damper pully only has one mark, and you set it to the timing marks on the timing gear cover, (Ironically the easier ones to see) you can be severly out of time.
