Offroad & 4x4
F150 Frame strength
Old Sep 9, 2011 | 11:19 AM
nobodyspecial's Avatar
nobodyspecial
F150 Frame strength
Ok. First of all, I know this has been discussed many times before. However, on my mobile device, posting a thread is hard enough, let alone trying to find one. FTE has to be the least mobile friendly forum i am on, it is so cluttered with garbage.
Anyway, I have a 95 F150 that could quite possibly get a leaf 1 ton and diesel swap. I know that you cant just throw axles under an F150 and call it an F350, my question is this. If i plate and box the F150 frame, can I approach or surpass the F350 frame in regards to torsional stiffness and rigidity? The diesel is not going to be built to insane levels, either. It will be relatively stock, not over 500 ft lbs.
The first person (and everyone after) that tells me to sell it and buy an F350 is getting pistol whipped.
I'm serious.
Old Sep 9, 2011 | 11:36 AM
Carlene's Avatar
Carlene
Admom
If it were me, I'd just sell the F150 and buy an F350 diesel.
Hey, I haven't been pistol whipped in a long time.
Old Sep 9, 2011 | 11:51 AM
alpha/omega's Avatar
alpha/omega
Originally Posted by Carlene
Hey, I haven't been whipped in a long time.
Josh,
Plate from the cab forward and from the front leaf spring hanger back with some 3/16" flat steel and fully weld it. It would be a good idea to sleeve and through bolt any removable hanger also.
Old Sep 9, 2011 | 11:55 AM
alpha/omega
I meant to remove "pistol" in Carlenes post.
I agree that fte mobile sucks
edit TJC : ya mean like that??
Old Sep 9, 2011 | 11:57 AM
fatdan460's Avatar
fatdan460
^^^what this guy said, and i'm not 100% sure on it, but if you have the crash impact zone crinckle frame horns you may have to chop them off and add box tube to make new frame horns to accomplish the leaf spring front. the crinkle part is weak on purpose and i wouldn't mount suspension to it without at least plating it or something like i suggested.
Old Sep 9, 2011 | 12:14 PM
nobodyspecial
Dont make me whip you Carlene! I'm not playing!
Thanks for the tip Kris. Dan, yes it has crumple zones and I already have an idea for those if this project gets the green light.
Since I am not going to inflict the torture of starting a new thread on myself, i will ask more questions here. What is the difference between a SRW and DRW Sterling?
oh and I would add FTE mobile to the things i hate thread if i could get there.
Old Sep 9, 2011 | 12:30 PM
fatdan460's Avatar
fatdan460
fte mobile does bring the suck, at least on my and your phones for sure. i can't even find the log in page half the time and then i can't reply after i do log in. it's like a perfect world for the rest of fte since i am silent
srw=67'' wms to wms drw=72'' wms to wms. thinking about h1's still?
Old Sep 9, 2011 | 01:04 PM
nobodyspecial
I dont know. this will be a work truck, pulling a 5th wheel flatbed.
Old Sep 9, 2011 | 02:32 PM
alpha/omega
I'm pretty sure the sterlings are the same wms -wms, dually or single rear wheel.
Its the offset in the rims that make up the width.
I think. Maybe.
Old Sep 9, 2011 | 02:38 PM
hav24wheel's Avatar
hav24wheel
Is that y you might be interested in my axles?
Idk if I'm going to sell them for sure now.
Wife wants a new rig, my 94 doesn't pull all that well. I'm getting a E250 or 350 with a 460 auto soon, so I might just sell the wifes jeep and the 94 and get her a expedition or sometjing and make the van a 4x4 with parts off my wheeler.
As for. Frame. Strength, boxing. It. Should make it plentu strong. For your needs.
Old Sep 9, 2011 | 03:53 PM
tjc transport's Avatar
tjc transport
i ain't rite
there are 2 different dual rear wheel 10.5 sterling axles.
you will want the pickup axle, it has wider spring perches and wider tubes to fit the wider pickup frame.
the cab chassis 10.5 axle is smaller due to the narrower frame on the cab chassis trucks.
Old Sep 9, 2011 | 04:01 PM
fatdan460's Avatar
fatdan460
yep, forgot about that tom i doubt he'll run into any cab and chassis in a junkyard or c/l ad, but good call.
also, josh make sure whatever axle you get has a vss port on the pumpkin up top so your speedo and abs work. early sterlings didn't have them. also if possible go for a 93 and newer axle as they have a longer pinion shaft that doesn't have the issues the short pinion axles had.
Old Sep 9, 2011 | 04:41 PM
tjc transport
i ain't rite
ya know what though Dan? here in joisey, you will find 1000 cab chassis 10.5 sterlings for every 1 pickup unit.
dually pickup rears never come on the market.
Old Sep 9, 2011 | 05:59 PM
nobodyspecial
thanks for the tip on the pinion, Dan. I knew I needed a Sterling with a VSS, but it is also highly likely that when a diesel will go in, all computer stuff will go as well. With a mechanical diesel, why would i keep other electronics?
What is the difference between 10.25 and 10.5 rears?
It is very possible that a 14b may be used, as well.
Dave, that sounds like a good project. I love vans. My Father in law has a nice 95 E with a 351W. He has considered trading it in, I am hoping he will give me first chance if he decides to unload it.
Old Sep 9, 2011 | 06:12 PM
fatdan460's Avatar
fatdan460
the 10.50 has the dumb metric lug pattern, only found in super duties, the diffs have 3 spider gears instead of 2 like a 10.25, the upside is they are all disk braked but none of that stuff swaps over to the 10.25. unless you found a matching set of super duty axles for cheap avoid the 10.50.
and just so you know, that vss sends signals to the abs crap as well. idk much about the diesels but be sure to get the hydroboost brake stuff with the motor from the donor as well or the vacuum pump thingamajigger if it's non hydro. diesels don't make vacuum on their own.
