Driveline vibration
Old Sep 9, 2011 | 09:33 AM
blacklab1's Avatar
blacklab1
Driveline vibration
I installed a Dana 60 front and a full floater rear diff in my 91 f-250. I now have slight vibration in 2 wheel drive, and considerable vibration when hubs engaged or in four wheel drive. I had the front shaft shortened and ballanced, all new ujoints front rear and axles. I've been told this may be a result of the pinion angle being wrong. Can I raise/lower the transfercase at the cross member, or do I have to shim the diffs?
Old Sep 9, 2011 | 04:38 PM
stuart1's Avatar
stuart1
You will have to eyeball both areas.
If the t/c is too high it puts great strain on ujoints closest.
If the differentials are too low or cockeyed the other ujoints suffer.
Old Sep 9, 2011 | 08:11 PM
79superduty's Avatar
79superduty
have a pic?
Nunez57
Feb 15, 2014 05:55 AM
97ExpGuy
Feb 9, 2009 07:35 PM
fd1109
13
Dec 5, 2007 06:32 PM
bigtorque
Nov 27, 2007 09:33 AM
Katmandu
1978 - 1996 Big Bronco
Nov 23, 2005 04:00 PM
