Steering Column
Old Sep 8, 2011 | 09:54 PM
pgr380's Avatar
pgr380
Steering Column
66' F100, 3 spd
Is there a coupling or spacer that fills the gap between the steering wheel and top of the column? I can't determine what is missing. The gap is about an inch or so.
Old Sep 8, 2011 | 10:10 PM
Broomfieldbum's Avatar
Broomfieldbum
Originally Posted by pgr380
66' F100, 3 spd
There should be a spring in there then the nut and it pushes the wheel down. I have a spare if you need it. Here is a picture of the exploded view of the column
Old Sep 8, 2011 | 10:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No spacer of any kind. If the wheel won't fit properly, it's either the wrong one or the column is out of adjustment.
Same THREE spoke steering wheel: 1960/63 Falcon/Comet / 1961/66 F100/250 2WD / 1966 F100 4WD / 1966/73 Bronco / 1967/72 F100/250 / 1969/70 F350.
EDIT: The spring (3520) has nothing to do with steering wheel fitment. It's used in conjunction with the upper bearing (3517).
C3DZ-3520-A .. Spring-Steering Column Upper Bearing.
Old Sep 9, 2011 | 11:01 PM
pgr380's Avatar
pgr380
Thanks for the diagram. How do I tell if I have the right wheel? It is a used replacement (found it on Ebay), and it appears to be exactly like the one I removed. It has the half moon horn ring instead of the horn assembly shown.
Thanks
Old Sep 9, 2011 | 11:06 PM
Broomfieldbum
Take a couple pictures, and post them up. If you don't have enough post to put picts up, send me a PM and I'll send you my email to verify.
My wheel is original, I think 17" Diameter, 3 spokes, and ribs all along the spokes.
Old Sep 9, 2011 | 11:23 PM
pgr380's Avatar
pgr380
Will do. You can see a picture of the old wheel in my album. The current one is just like it (without the cracks, scratches and missing chunks).
Catanna69
Ford Truck Parts for Sale
Dec 2, 2016 05:56 AM
ram1each
Dec 28, 2012 07:13 AM
likeagoodbook
Jul 6, 2012 12:31 PM
al barbour
Sep 22, 2010 03:34 PM
ksteen
Mar 2, 2010 07:17 AM
