Sponsored by: Real Truck
back up lights
Old Sep 8, 2011 | 07:43 PM
gene17847's Avatar
gene17847
back up lights
can anyone tell me were the back uplight switch is located on my 03 f350 6.0 auto trans my lights are not working and the fuse is good along with the bulbs so i think its the switch all i have to do is find it to test it
Old Sep 8, 2011 | 07:48 PM
mach8274's Avatar
mach8274
If I remember correctly, and someone please correct me if I'm wrong, the reverse lights are switched on by the transmission range sensor on the side of the tranny.
Old Sep 8, 2011 | 09:08 PM
dchamberlain's Avatar
dchamberlain
The PCM closes a relay, based on input from the transmission range sensor. So there is no switch. I would look at the fuse, first off.
Old Sep 9, 2011 | 12:27 AM
Andrew010's Avatar
Andrew010
Check the ground also.
2jhanna
Nov 22, 2006 02:31 PM
stigedis
1997 - 2003 F150
Jun 10, 2006 08:25 AM
BIG-COUNTRY
Electrical Systems/Wiring
Nov 15, 2005 05:34 PM
